03-28-2016, 08:51 AM | #1 |
Newbie Join Date: Nov 2015
| Which winch works best?
Hey all. Just had a couple questions on winches with my rtr receiver. I did want the rc4wd warn winch but didn't know if I could program my controller to operate the winch or do I have to buy a separate controller of some sort. Or could I go with the 3racing winch but couldn't really find any specs on it as to what It is able to handle and if it can work off my third channel on the ttx300. Any thoughts or advice on which route to take would be much appreciated. Sent from my SM-G903W using Tapatalk |
03-28-2016, 11:36 AM | #2 | |
RCC Addict Join Date: Feb 2008 Location: Tekin, ID
| Re: Which winch works best? Quote:
03-28-2016, 12:30 PM | #3 |
Rock Crawler Join Date: Aug 2015 Location: Big Island
Check out HeyOK's RC Electronics items (all in one place). He's got winch controllers that will work from a two or three position third channel.
03-28-2016, 12:49 PM | #4 | |
RCC Addict Join Date: May 2015 Location: Price Twp.
My servo winch makes my sons 3racing winch look like a little girl. Using the ttx300 will result in the winch coming on every time the receiver is turned on. It is kind of a PIA but you get used to it. I'm using a old servo controller for the 3racing winch. The servo winch uses a heyok controller for a two position switch and works like a charm. Against heyok's explicit recommendations, advice and instructions it is holding up nicely on a 7.4v BEC. I have come to accept if it fails it is my fault, but it is fuse protected and I have yet to burn up a fuse. | |
03-28-2016, 01:29 PM | #5 | ||
Sent from my SM-G903W using Tapatalk Last edited by THX_138; 05-17-2016 at 09:05 AM. Reason: Merge, posts a minute apart | ||
03-28-2016, 01:41 PM | #6 |
RCC Addict Join Date: Nov 2011 Location: Surrey,BC- Canada
Just so you know, if you get in touch with heyok, he can ship directly to you. He lives in Vancouver Canada.
03-28-2016, 01:58 PM | #7 | |
I got the heyok controller because my truck uses a 2 position switch, so I had no other options. I am very happy with it and 417oz servo. I have to say that using the winch off the BEC provided with the stock Deadbolt receiver is pretty wimpy. It does work but it is slow and it really sounds like it is struggling. If money is an issue you could just get one of those cheap tower clones from ebay. Use two of the round servo horns, and put a spacer between them with some epoxy. The just add a longer screw to secure it, assuming you pull the stoppers out of the servo gear. For $4-6 you have a usable winch until you can get your self squared away for something a little better. Last edited by Ditchrat; 03-28-2016 at 02:03 PM. | |
03-28-2016, 02:00 PM | #8 | ||
Thanks for all the great feedback Sent from my SM-G903W using Tapatalk Last edited by THX_138; 05-17-2016 at 09:07 AM. Reason: Ditto | ||
03-28-2016, 02:06 PM | #9 |
RCC Addict Join Date: Mar 2009 Location: The REAL Nor-Cal
| Re: Which winch works best? |
03-28-2016, 02:30 PM | #10 | |
You will also find lots of information on the TTX300 3rd channel. I literally received the kids deadbolt on 3/19 and by 3/19 plus 4 hours found tons of forum post, found an old servo in the basement, solder the winch to the output of the servo, read the programing instructions and mounted the winch to the bumper. If I knew what I was doing it would have taken 15 minutes. Reading the programing instructions took the longest. I was going nuts trying to get it programmed so that when the transmitter is turned on the winch wouldn't move. Turns out that's how it is and there is nothing that can be done about it. So I cut the lead and installed an on off switch so my kid cant bind the winch up or rats nest it when he turned the transmitter on. | |
03-28-2016, 03:15 PM | #11 | |
Sent from my SM-G903W using Tapatalk | |
03-29-2016, 12:48 PM | #12 |
Time to post this! Another servo winch building tutorial |
03-29-2016, 01:37 PM | #13 |
Using the servo controller does work, mine did for about a year on my Wraith but now it never wants to stay in the "center." I glued the potentiometer inside and it lasted, but now it floats and will start spooling in or out randomly. I planned on taking the guts out and just using an external controller. In my JK I used a B1R (our micro brushed ESC) to control a TziWorld Beefy Winch. It's worked great and is total overkill.
Which winch works best? - Similar Threads | ||||
impulse winch buy, rc4wd, custom bumper and winch pull test | evan03 | Axial Wraith | 13 | 03-10-2013 09:15 PM |
3racing Winch only works one way | James003 | Electronics | 5 | 09-14-2010 06:20 PM |
winch wiring? it works but.... | 00TJ | General Crawlers | 3 | 01-19-2007 06:24 PM |
