Go Back   RCCrawler Forums > RCCrawler General Tech > Newbie General
Thread: Trans rebuild help
Old 06-19-2017, 05:43 AM   #1
Default Trans rebuild help
I have a scx10.II running a stock servo and receiver/transmitter. The motor is a castle creations 2850 crawler and the ESC is the mamba monster X. Everything else is stock on my rig. Oh it's an rtr rig.
Im looking for help on how to make the transmission bullet proof. Any help would be greatly appreciated, thank you in advance.
Sent from my SM-N920V using Tapatalk
Oger1983 is offline   Reply With Quote
Old 06-19-2017, 05:52 AM   #2
Default Re: Trans rebuild help
I'd suggest grabbing an RC4WD AX2 2 speed transmission. For what you're going to spend in the upgraded bearings, upgraded gears and case, it'll only be a few more bucks to grab the 2 speed, and you'll end up with better crawlability and better top end
Sent from my LG-H830 using Tapatalk
excabswap is offline   Reply With Quote
Old 06-19-2017, 06:10 AM   #3
If you are running SCX10 II RTR Then go to SuperShafty boom proof tans
https://supershafty.com/collections/...mb-proof-trans
Teng is offline   Reply With Quote
Old 06-19-2017, 06:25 AM   #4
the 2 speed trans is pointless on the sensored brushless setup you have, you can buy the HR aluminum cased trans complete with steel gears on ebay for 88 bucks...This is what I do when I feel the need for a HD trans.
allanon1965 is offline   Reply With Quote
Old 06-19-2017, 07:55 AM   #5
Thank you all for the replies. I'll take some time look them over and compare them and make a decision and hopefully have something by the end of the week.
Old 06-19-2017, 11:46 AM   #6
Thank you all. I went with the HR pre assembled for now. It was affordable and will be here Thursday. Got a social crawl this weekend.
Trans rebuild help - Similar Threads
Lcc trans. rebuild ? Robb8 Team Losi Comp Crawler 7 04-28-2010 05:07 PM
R2 Trans Rebuild Kits Reef RCP Crawlers 0 10-16-2008 01:13 PM
HTML code is Off
