Go Back   RCCrawler Forums > RCCrawler General Tech > Newbie General
Thread: What wires for Tekin - Mamba X connection?
Old 10-03-2017, 02:19 PM   #1
Default What wires for Tekin - Mamba X connection?
This really is a newbie question, please bear with me.
I have started to gather parts for a Yeti build and today I got my Tekin Pro4 HD. Nice! But how do I connect it to my Mamba X? I thought wires would be included with either the motor, or with the ESC, but no.
What kind of wires and connectors do I need to buy? I am placing an order with Tower Hobbies within the next couple of days and hope to get this in as well, but do not really know what to look for. Could I use any kind of electrical wire? What gauge will I need? Bullet connectors?
Links would be most appreciated, it's a jungle out there...
Antsiranean is offline   Reply With Quote
Old 10-04-2017, 03:14 AM   #2
Default Re: What wires for Tekin - Mamba X connection?
on the mamba x you have 4mm female bullet connectors, so u need 4mm bullet male too connect the 3 motor wires. as wire i'm not sure but 10 or 12 awg silicon wire should be ok.
castle has a set of 3 4mm connectors http://www.castlecreations.com/en/co...cc-bullets-4mm
Gesendet von meinem T1-A21L mit Tapatalk
magic_yeti is offline   Reply With Quote
Old 10-04-2017, 03:19 AM   #3
Thanks! And then I just solder the wires directly to the motor? Maybe some heat shrink over the motor connections as well?
Old 10-04-2017, 06:05 AM   #4
Moderator
you don't need heat-shrink over the motor connections. They're spaced far enough apart not to have issues. Plus if you heat shrink over it, you'll just have that much more work when you unsolder in the future.
I would recommend that you put some heat-shrink over the bullet connectors though. On a crawler you'll probably never have an issue, but on other vehicles a hard crash could bend them together, or if you use it with a different ESC that has the bullets at the end of a wire, you'll want some isolation.
Jim85IROC is offline   Reply With Quote
Old 10-04-2017, 12:03 PM   #5
Thanks a lot! 4mm bullet connectors and 14AWG silicone wire is to be ordered.
Old 10-04-2017, 12:13 PM   #6
Moderator
14 AWG will probably be ok in a crawler, but it seems a bit small to me. For something like a Tekin Pro4 HD, I'd use 12 AWG.
Old 10-05-2017, 05:36 AM   #7
Do you think 12AWG will fit the bullets? Specification says they are for 13-16AWG.
Old 10-05-2017, 06:59 AM   #8
Moderator
It should. Worst case is you can cut away a few strands until it fits. As long as you solder it well, it will be fine.
Old 10-05-2017, 09:33 AM   #9
Thanks again, I really appreciate your help! 12AWG it is.
Old 10-05-2017, 11:29 AM   #10
as we are at soldering. easiesed way to solder bullets. drill a 4mm hole in a peace of wood, so the small hole on the side of the bullet is clear. than put bullet in and use a solder tip that fits the hole. fill the bullet half way with solder and then stick the wire in the fluid solder.
i managed 10 awg in 4mm bullets so 12awg should fit.
Old 10-09-2017, 12:39 PM   #11
I would tin the wires first.
DavidH is offline   Reply With Quote
Old 10-09-2017, 01:21 PM   #12
oh sry forgot that
What wires for Tekin - Mamba X connection? - Similar Threads
Water? Dust? Broken wires? Bad Connection? Help please! XcrawlerkidX Electronics 12 10-17-2012 07:12 PM
Tekin FXR wire connection issues. americanricer87 Electronics 8 07-17-2012 12:08 PM
Connection wires?? demonoid369 Chit Chat 6 09-21-2011 11:19 PM
Mamba Max / Crawlmaster Connection Question. wshipley Electronics 3 08-05-2007 02:34 PM
Mamba to Crawlmaster connection questions Mr_Freeze Electronics 12 07-27-2007 01:31 AM
