08-08-2018, 09:02 PM | #1 |
Rock Stacker Join Date: Apr 2009 Location: Chino Hills
| gearing question
I have a twin hammers built from a kit with a hh torquemaster 13t motor controlled by a brxl escand I burnt the motor in a 30 minute run on 3s. I am using the original 78t spur but i went down to a 22t pinion from 28 which was the lowest pinion for that spur in the chart. justin at HH recommends getting the final drive down to 35:1 but being new to changing gears how would I achieve this while being able to keep the speed up as it will spend most of its life in high gear with the occasional crawling. any help is appreciated as I just want to drive this thing. thanks
08-08-2018, 09:03 PM | #2 |
| Re: gearing question
ring and pinion ratio is 2.86 and trans is 2.27 if that helps
08-08-2018, 11:17 PM | #3 |
RCC Addict Join Date: Nov 2016 Location: 1972 born Christian, Chinese.
Simple just change the motor to high kv brushless motor. Cheers
08-08-2018, 11:58 PM | #4 |
Quarry Creeper Join Date: Mar 2018 Location: Indonesia
Try asking John Holmes at Have tech questions? Will answer. for an answer. I'm pretty sure he will recommend a brushless 3500KV or something similar for your use.
08-09-2018, 05:59 AM | #5 |
their website recommends the torquemaster 13t
08-09-2018, 10:04 AM | #6 |
Have a look at the Holmes Hobbies YouTube channel and see what John says about brushed versus brushless for bashing vs crawling. No one motor can do everything well, it's all about trade-offs.
08-09-2018, 07:09 PM | #7 |
you need to get the spur and pinion ratio down towards 5:1 to give that 13t torque master any chance for survival...
08-09-2018, 08:31 PM | #8 |
i'm not sure how to do that I've never had to switch gearing around before. I would love some input y'all speaking Greek to me
08-13-2018, 08:22 PM | #9 |
| Re: gearing question Twin Hammers Gear Chart You can get a 22t pinion for Twin hammers and it will put you at 40/1, slow you down and save motors. Also a higher T (turn) motor like 27t will slow you down as well. But slow it down with gears first in my opinion. Last edited by Voodoobrew; 08-13-2018 at 08:31 PM. |
08-13-2018, 09:20 PM | #10 |
I had the 22 pinion in the rig when the motor went south.
08-14-2018, 01:01 AM | #11 |
Does the drive train spin freely? That could over heat motors too.
08-14-2018, 06:50 AM | #12 |
yup no binding whatsoever.
08-14-2018, 08:10 AM | #13 |
Rock Crawler Join Date: May 2018 Location: USA
He recommends the crawl master 13t, NOT the torquemaster. That motor will fry at that gearing, as it did. Everyone I see running a twin hammers on here goes brushless though, that’s a heavy fast rig.
08-14-2018, 12:08 PM | #14 |
per their motor recommendations page I ordered the torquemaster but since it failed will rebuild it and try and sell itand the esc as I just ordered a brushless setup
gearing question - Similar Threads | ||||
Gearing question | Sloppy44 | Axial Yeti | 4 | 02-15-2016 09:43 AM |
Gearing Question | old man 52 | Losi Micro-Rock Crawler | 10 | 11-02-2015 04:04 PM |
gearing question | turdferguson | Axial Wraith | 0 | 02-11-2012 01:15 PM |
WK Gearing question | Stein | HPI Wheely King | 8 | 03-14-2008 02:13 PM |
Gearing question, | Magic | Chit Chat | 0 | 03-10-2008 02:47 PM |
