02-03-2021, 01:28 PM | #1 |
Newbie Join Date: Jan 2021 Location: Portugal
| Stripped motor pinion on my crawler
Today I stripped the motor pinion on my crawler and I wanted to ask you guys if you have any clue why. I was hill climbing a sandy muddy hill and then I started hearing some loud noises and I decided to head home. I found out my metal motor pinion is stripped, the spur seems fine (also metal) though. I had greased the pinion/spur and this is inside a closed compartment but there was still sand and dirt in there. Why do you think the pinion stripped? Too much sand/friction, bad assembly/spacing between the pinion and spur or loose motor screws (they didn't have threadlock)? I've also heard that having an all metal pinion/spur combo is bad because there's nothing that "gives" but I don't think this was the case because the pinion actually gave away. All of these are possible options IMO, would they cause the pinion to strip? |
02-03-2021, 01:41 PM | #2 |
Quarry Creeper Join Date: Jul 2019 Location: Torrance, CA
| Re: Stripped motor pinion on my crawler
You are right, all of those are possibilities for sure. Another thought that comes to mind is, was the spur hardened steel and the pinion not? If so, it could just be a case of one metal was stronger than the other, so something had to give. |
02-03-2021, 02:18 PM | #3 |
I have no idea but I'm kinda happy it was the pinion (the least expensive piece in there) and not the spur or even worse some gear in the gearbox. I'm also wondering if the grease might accumulate more sand and dirt vs dry spur/pinion resulting in more friction
02-03-2021, 09:53 PM | #4 | |
Quarry Creeper Join Date: Jul 2020 Location: US
| Re: Stripped motor pinion on my crawler Quote:
R.C. means both;Radio control, and Rock Crawler, oh..and Race Car! annd, Rice Cake, as well as ..Real cash, Remote Contr, etc | |
02-04-2021, 09:34 AM | #5 |
RCC Addict Join Date: Jan 2016 Location: Kelowna, BC
| Re: Stripped motor pinion on my crawler My guess would be that the pinion was aluminum and the spur was steel, that's a fairly common configuration. It's almost as effective a fuse as steel pinion/plastic spur.
02-04-2021, 03:59 PM | #6 | |
I think the spur is black painted steel and the pinion has a gold raw color so it's probably.. brass?? | |
02-05-2021, 09:59 AM | #7 | |
As for grease, I always grease gears if they're metal on metal. I can definitely understand the argument for not doing that if they're exposed but if they're encased, I'd put a little grease on them. That pinion'll spin at up to 30k rpm (or more) and doing that without grease could increase the heat (not much obviously but possibly enough to soften fine edges of aluminum gear teeth, there's a lot of friction in gear meshes) which might lead to increased wear of the soft aluminum pinion gear. That's just my thoughts though and I don't claim to be an industry leading expert or anything.. | |
02-05-2021, 07:39 PM | #8 |
Quarry Creeper Join Date: Feb 2016 Location: canada
I've also seen bad bearings cause the spur and pinion to separate at high torque or speed also causing the pinion to strip Sent from my SM-G975W using Tapatalk |
02-05-2021, 08:21 PM | #9 |
I've never lubed a spur and pinion with grease. If i ever needed to, i would use bar soap as a lubricant on those as it doesn't attract dirt.
Stripped motor pinion on my crawler - Similar Threads | ||||
Stripped pinion gear | fshnut007 | Axial Yeti | 11 | 12-19-2015 09:01 AM |
Redcat Super Crawler motor pinion | Jayzrc | General Crawlers | 0 | 10-08-2012 03:01 PM |
stripped ring and pinion!?!? | RBCcrawler | Losi Mini-Rock Crawler | 12 | 10-14-2009 08:38 PM |
Stripped pinion yoke set-screw! | XPLORx4 | General Crawlers | 3 | 05-06-2009 08:31 PM |
stripped pinion from the factory. | mannysouza | Axial AX-10 Scorpion | 7 | 10-03-2007 08:21 AM |
