02-14-2022, 11:01 AM | #1 |
Newbie Join Date: Nov 2020 Location: East Springfield
| Wheel Clearance
Building my first SCX10II. My wheels are just a little to close to my tie rod as my tire slightly rubs. How would I shim this for more clearance? It doesn't need much. Thanks
02-14-2022, 11:40 AM | #2 |
I wanna be Dave Join Date: Jun 2020 Location: The Big Island
| Re: Wheel Clearance
Which wheels did you go with? That would help us get you the help you need. But regardless of wheel choice, you could just get a hex adapter off Amazon anywhere from 4mm to 30mm. I wouldn’t go above 10-15mm though, they seem to be weak link plus it’ll look weird on the axles. For you’re situation, you really only need around 7mm. Sent from my iPhone using Tapatalk |
02-14-2022, 11:59 AM | #3 |
| Re: Wheel Clearance
I went with RC4WD Rally 1.9" Beadlocks. Description says will fit SCX10 II, but really close, thus slight tire rub. I have a pic but can't seem to figure how to post it
02-14-2022, 12:08 PM | #4 | |
| Re: Wheel Clearance Quote:
Yeah I would just get some hex adapters off Amazon. You can get a set for a few dollars. I run a couple of pairs of these one of a high powered rig and they have held up fine: https://www.amazon.com/Atomik-RC-All...bap_m_rp_38_sc Sent from my iPhone using Tapatalk | |
02-14-2022, 01:55 PM | #5 |
| Re: Wheel Clearance
Thanks just ordered them
Wheel Clearance - Similar Threads | ||||
Issue with rear lockout and wheel pin clearance. | Drm31078 | Axial RR10 Bomber | 6 | 09-26-2016 04:02 PM |
Wheel Base and ground clearance question | calikingcrawler | General Crawlers | 1 | 03-16-2009 02:03 AM |
RCP ~ Axial 8-Hole Wheel Clearance! $16.99 | pigeonfarmboy | Tires and Wheels | 0 | 10-15-2008 07:17 PM |
Clod Motor-Wheel Clearance | DKNguyen | Tamiya Clod Buster | 1 | 10-08-2007 05:33 PM |
