05-20-2012, 08:17 PM | #1 |
Quarry Creeper Join Date: Mar 2008 Location: virginia beach
| Making a smooth surface on lexan
Im putting 2 unimog bodys together, making it 4.door. i know im gonna habe to paint on the outside but what should i do to attach tjem together and smooth i out so you cant tell there connected. What do i need and what should i do? Sent from one of those new boxes you can talk thru and hear sombody else in it. |
05-25-2012, 06:29 PM | #2 |
| Re: Making a smooth surface on lexan
I'venever seen a seemless joined lexan ody efore. your best bet it to make a clean straight cut, and butt match them together, and use a strip of lexan shoegoo'd to the inside. Most types of body filler will crack when the lexan bends. You could probably get away with using shoe goo to fill in the gaps, and just quickly wi[e off the excess and smooth it out as best as possible. Then just paint over the exterior like you mentioned. You might also want to try and hide yout cuts by using an existing body line as the join point.
05-25-2012, 07:22 PM | #3 |
I used a line from the original body's to cut. I am using plastix still by KB weld. Its hard as a rock.and even bending the body doesn't give at all. I smooth one side and its near to perfect. Better than I thought it would be. I dremeled down close then sanded. Sent from one of those new boxes you can talk thru and hear sombody else in it. |
05-25-2012, 07:36 PM | #4 |
Check out my Tuesday called daddyducks unimog in the 1.9 scalers Sent from one of those new boxes you can talk thru and hear sombody else in it. |
06-29-2012, 07:44 AM | #5 |
Newbie Join Date: Jun 2012 Location: frankfurt germany
i am kinda in the same boat, wanting to cut up a lexan fj40 body to make it work on a wraith. now i think i have some ideas on how to join the lexan back together, thanks
Making a smooth surface on lexan - Similar Threads | ||||
making your own lexan bodies? | theloudone | Paint and Body | 2 | 05-18-2012 08:51 PM |
work surface | moron88 | Tools, and Procedures | 9 | 03-13-2011 11:08 PM |
need help making it smooth again | crawler nub | 1.9 Scale Rigs | 2 | 12-28-2010 09:29 PM |
I was waiting for these to surface | JasonInAugusta | Chit Chat | 78 | 06-02-2008 06:21 PM |
