Go Back   RCCrawler Forums > RCCrawler General Tech > Paint and Body
Thread: Paint is curling or lifting
Old 05-06-2014, 03:25 PM   #1
Default Paint is curling or lifting
Hello peoples...
I am new to the whole painting of my RC cars. I just recently purchased a trail finder 2, I scuffed up the body and washed it with dawn dish soap. after letting it dry I sprayed it down with primer and again let it dry. when I went to spray on the color the paint seem to curdle, web, left I'm not sure the correct term Off the body. Any ideas. I'll try and get a picture loaded.
MEnMYshoes is offline   Reply With Quote
Old 05-06-2014, 06:47 PM   #2
Default Re: Paint is curling or lifting
I think you used an automotive primer and then went over it with acrylic. List the primer/paint brands and formulation.
shahram72 is offline   Reply With Quote
Old 05-06-2014, 10:22 PM   #3
We use to call that orange pealing, wrong primer to finish coat, like painting a 90 year old person, kind of wrinkly. cheers
Fiftygrit is offline   Reply With Quote
Old 05-07-2014, 08:30 PM   #4
The first primer was a rust-oleum primer White and the paint is a Dupli-color. I sanded the whole thing down and went with a Dupli-color primer.
Old 05-15-2014, 09:28 AM   #5
Did that solve the problem?
Primer should really be allowed to sit for a day or two before top coating.
rcwolf is offline   Reply With Quote
Old 05-23-2014, 07:23 PM   #6
It could be from something getting on the primer after you let it dry, Its having a reaction to what ever is on the body. I would wet sand the primer and hit it again and let it dry for a few hours. then clean it really well before spraying your top coat.
JonnnScott is offline   Reply With Quote
Old 05-28-2014, 02:22 PM   #7
Fan of wheelspeed
More than likely the primer isn't happy with the top coat. It can also be caused by applying to heavy of a top coat. Try painting in very lite coats this time around. You will basically over spray the truck with your first coat. Let it sit for several hours in the sun or over night even before touching it. Then wet sand lightly and follow up with your 2nd coat.
-just spotted that this thread is kinda old. You probably have it finished by now.
Hoosierdady is offline   Reply With Quote
Old 06-02-2014, 11:48 PM   #8
Should it then be varnished or sealed in any way?
Ghost Cypher is offline   Reply With Quote
Paint is curling or lifting - Similar Threads
Lifting honcho rednutz10028694 Axial SCX-10 15 03-07-2014 12:56 AM
scx10 lifting help zoner89 Axial SCX-10 9 01-10-2014 03:12 AM
Power Lifting... DrasticSports.com Chit Chat 44 11-19-2007 12:24 AM
US Womens Curling team Grape Ape !!! Chit Chat 13 02-17-2006 03:27 PM
