01-19-2013, 01:42 PM | #1 |
Quarry Creeper Join Date: Sep 2012 Location: 01011
| Plastic Adhesives??
Im in the midst of hacking and cutting a Nikko Toyota Tundra Xtra cab to a single cab: While its going good so far I need to know what I can use for the strongest of bonds to the plastic seams: All ive done so far is a couple of dots of superglue to hold it to the basic shape im looking for. i have experience with Tenax and Ambroid Proweld on styrene but noticed that during my JK build that it didnt necessarily bond plastic hardbodies as well as the styrene you can get from the LHS. Ideally I need a bond that can withstand rollover after rollover after rollover (Not sayin much for my driving skills!! ) without coming undone. Any pro or even pro-ish help would be much appreciated |
01-20-2013, 12:23 PM | #2 |
Quarry Creeper Join Date: Jun 2012 Location: Earth mostly
| Re: Plastic Adhesives?? Epoxies : Permatex® PermaPoxy I've had good luck with this stuff. Sets up fast too so you don't have to sit there hold the pieces together for an hour |
01-20-2013, 04:15 PM | #3 |
Bieng an epoxy I dont think it will "bond" the plastic as much as glue it together. thanx for the tip and I will research but still lookin for more feedback
01-20-2013, 04:29 PM | #4 |
Quarry Creeper Join Date: Aug 2007 Location: Bowling Green KY
Tenax & Bondene is what I was told to try.
01-20-2013, 09:10 PM | #5 |
SORRCA Committee Member Join Date: Dec 2008 Location: Parkston, SD
Since most of the New Bright and Nikko bodies are made with ABS, I use C/A to hold the pieces together then back it with ABS pipe cement. The cement creates a strong bond by fusing with the body. Works like a charm and is fully sandable, and it also paints just fine.
01-21-2013, 06:16 AM | #6 |
Thanx guys. Think Ill give the ABS glue a shot. I like the fact it will be somewhat flexible as well so it will "bend' and twist without breaking.
01-21-2013, 07:27 AM | #7 | |
| Re: Plastic Adhesives?? Quote:
Your right it does stay somewhat flexible, but still creates a strong bond. Plus the other benefit is it is very easy to sand and shape if you use it as a filler also. | |
02-14-2013, 01:56 PM | #8 |
Newbie Join Date: Jan 2013 Location: Boise
Hey I'm in the crew cab process on my Tamiya Blackfoot... Not to hijack your thread or anything but can anyone verify if the new Tamiya bodies are ABS as well? Last edited by kart45; 02-14-2013 at 01:58 PM. Reason: added image |
02-15-2013, 11:34 AM | #9 |
Newbie Join Date: Feb 2013 Location: Brisbane/Australia
Noe is it fix properly and there is something remain in adhesive?
Plastic Adhesives?? - Similar Threads | ||||
Plastic rings | redemon | Losi Mini-Rock Crawler | 2 | 06-24-2011 12:30 PM |
Cutting plastic | thumper68 | Tools, and Procedures | 4 | 06-08-2010 11:04 AM |
Need to know the best plastic on plastic friction reducer. | TurboB18C | Chit Chat | 2 | 04-06-2005 04:28 PM |
