04-30-2013, 10:28 AM | #1 |
RCC Addict Join Date: Feb 2010 Location: New Jersey shore
| possible to remove paint from a lexan body?
tried a few things nothing worked so far.. i cant even the get the sticker residue to come off the damn body. thought for sure rubbing alcohol would do it just spreads it around the body.. any ideas thanks |
04-30-2013, 05:06 PM | #2 |
RCC Addict Join Date: Aug 2011 Location: Elkhart
I know there are several threads on how to do this, I've never done it myself but I think people are using a certain kind of brake fluid, I'm sure more will chime in soon, if that fails type paint removal in the search bar and some threads should pop up! Good luck!
04-30-2013, 07:01 PM | #3 |
Newbie Join Date: Sep 2005 Location: holts summit
| Re: possible to remove paint from a lexan body?
Brake fluid works, you have to let it soak for a couple days sometimes and keep it wet, get a tub and plenty of brake fluid and keep as much submerged as possible and keep flipping it around. It took me several days to clean an old clod body I did.
04-30-2013, 08:00 PM | #4 |
Rock Crawler Join Date: Feb 2011 Location: s. terra firma
Lost wages, the clod body is not lexan is it not? I thought that it was a plastic based body? Cause I too would like to know? Thanks.
05-01-2013, 07:41 AM | #5 |
The clod body is styrene, but paint is paint, the last body I stripped was an old losi jrxt body, it is lexan and it worked the same way. Just don't expect to pour on some brake fluid and wipe off the paint, it needs time to soak.
05-01-2013, 03:23 PM | #6 |
Rock Stacker Join Date: Nov 2004 Location: middle of nowhere
use dot 4 brake fluid. takes some soaking time but it works. I let it soak and scraped it off with plastic spoon and used a scotch bright also.
05-01-2013, 03:43 PM | #7 |
Quarry Creeper Join Date: Jun 2010 Location: lexington nc
I used super tech dot 3 brake fluid from walmart let It soak for bout two hours an most came off strained the fluid an poured bak in with body an let it sit for two more then finished an washed
05-03-2013, 09:39 AM | #8 |
ok it worked. took a long time but it did.. how do i get the adhesive off the body from old decals? thanks
05-04-2013, 09:44 AM | #9 |
RCC Addict Join Date: Mar 2010 Location: Yelm
Use lighter fluid to get the stickies off of it.
05-04-2013, 09:55 AM | #10 |
ok thanks
05-05-2013, 12:18 PM | #11 |
Rock Stacker Join Date: Feb 2006 Location: Ringgold
| Re: possible to remove paint from a lexan body? |
05-05-2013, 07:56 PM | #12 |
thanks
05-05-2013, 10:21 PM | #13 |
Quarry Creeper Join Date: Jan 2009 Location: B-E-A-utiful Vancouver Island
05-10-2013, 07:41 AM | #14 |
RCC Addict Join Date: Nov 2008 Location: Frederick
05-11-2013, 07:35 AM | #15 |
thanks for the link
possible to remove paint from a lexan body? - Similar Threads | ||||
Whats the best way to remove paint from a RC body? | AXLE 69 | Paint and Body | 6 | 02-10-2013 06:21 AM |
How to: Remove paint form a hard body | msd44 | Paint and Body | 11 | 02-11-2011 07:43 AM |
How to: Remove paint from lexan bodies | mycrors7 | Paint and Body | 2 | 08-14-2010 11:53 PM |
Tamiya TS paint on lexan body? | timh | Paint and Body | 2 | 06-16-2010 01:57 PM |
Lexan body paint Q..... | mrpink | Paint and Body | 9 | 11-16-2006 08:07 AM |
