11-13-2013, 04:15 AM | #1 |
Rock Crawler Join Date: Oct 2013 Location: Wiscasset, ME
| Anybody paint their truck with plasti dip?
First off, the search function isn't working on my mobile phone... Idk I got my dingo kit, painted the body had it all nice and cool using krylon plastic and rustoleum plastic paint. First run it chips!!! I want to redo it and will soak it in dot 4, but if I manage to clean it all up I want to do it right. Heard that automotive grade paint may work or the tamiya paints, but I'm curious about plastic dip too. I'll have to order the good paints, but I was wondering if you guys have some tips. I'm kind of a perfectionist and would like to do it right. Thanks in advance, if there is a thread about this feel free to link it to me. |
11-13-2013, 06:56 AM | #2 |
RCC Addict Join Date: Dec 2006 Location: Oak Ridge, TN
| Re: Anybody paint their truck with plasti dip?
Use lexan paint for lexan bodies. Plasti-dip would make for a heavy body it's not ideal neither is auto paint.
11-13-2013, 07:30 AM | #3 |
Rock Crawler Join Date: Jun 2008 Location: Clinton,Michigan
yea search button doesn't work on my mobile phone either :( if you don't have an airbrush then use pactra spray paint. very important to clean inside of body really good. especially after you use brake fluid. I have never had much luck with the body turning out very good after stripping the paint. always seemed to scratch the body and or fog it up. personally if it were me I would consider a new body altogether. I know it sucks and I am not made of money either but that is what I would do |
11-13-2013, 07:34 AM | #4 |
A new body is probably easier. Been looking for one. The dingo was cheap but the body is more boxy than I'd like. Ordered a lift kit and some 2.2's so maybe I'll pick up a thinner ()---() body soon. The width is what I'm referring to. If you guys happen to have suggestions on that topic also, let me know.
11-13-2013, 07:42 AM | #5 |
I wanna be Dave Join Date: May 2009 Location: Tehachapi,Ca
I used plasti dip on the roof of the axial jk the finish came out perfect for the look, no chips but when it get dirty/ or dusty you have to run it under water to get it off, it doesn't just wipe off. I've also had it on the bumpers and wheels of my real truck for the last 2+ years with no problems at all |
11-13-2013, 10:54 AM | #6 | |
| Re: Anybody paint their truck with plasti dip? Quote:
11-13-2013, 10:55 AM | #7 |
Spray
11-13-2013, 02:59 PM | #8 |
Rock Stacker Join Date: Dec 2012 Location: SF Bay Area
I did plasti-dip on my hard body toyota. It gave it the stealth look but it is a dust magnet and it will peel off at the sharp edges of the body (wheel wells, bumpers and around the window openings). The coats were very thin in those areas. I guess you would probably yield better results if you spray on the plasti-dip thicker at these areas first then work towards the body panels. Something to watch out for.
11-15-2013, 07:17 AM | #9 |
I think I might go with a hard top body now. Get myself a new bright. No painting and they look B A !
11-17-2013, 06:34 AM | #10 |
Rock Crawler Join Date: Jul 2013 Location: Kansas City
I used it on my Jk hard top and the result is awesome it looks just like a real hard top . Plus I think it quiets down the lexan ratteling
11-17-2013, 10:15 AM | #11 |
Newbie Join Date: Oct 2011 Location: USA
This was my first time using plasti dip on a lexan body. I learned that I need to cut the body and drill the holes first or the plasti dip will catch the drill bit and pull off the body. Plus it takes a long time to do the body, well at least it took me awhile to do because all I had around the house was the brush on plasti dip and I let each coating dry before I put on the next. You can also see around the edges of the body where I trimmed, that is the plasti dip. James |
11-19-2013, 02:23 PM | #12 |
Thanks for posting all those pictures!! I would use the spray myself. Looks pretty good. I'm waiting for my botched paint job to flake off so I can redo it the right way. Either plasti dip or lexan paint. Krylon "plastic" paint is a no-no! Oops
11-19-2013, 02:31 PM | #13 | |
Newbie Join Date: Mar 2011 Location: wisconsin rapids
if you wanna try stripping the paint back off,i used an automatic airsoft gun and it worked as a bead blaster....we got a hell of a kick out of it too | |
11-19-2013, 04:40 PM | #14 |
It may make it heavy but I've heard of people lining the body after paint with plasti dip and making it more durable.
11-19-2013, 07:36 PM | #15 |
Properly applied lexan paint will outlive the body.
Anybody paint their truck with plasti dip? - Similar Threads | ||||
Plasti-dip caution. | mett1971 | General Scale Talk | 13 | 05-28-2013 05:50 AM |
plasti-dip batteries | Docwolf | Electronics | 10 | 05-12-2012 08:36 PM |
Plasti Dip Help. | Butcherinhd | Tools, and Procedures | 14 | 09-22-2011 09:57 PM |
Plasti-Dip | Veritas | Electronics | 4 | 05-19-2011 11:18 PM |
Plasti Dip? | KENNYKILLER14 | Electronics | 3 | 01-03-2007 08:13 PM |
