11-20-2013, 01:23 PM | #1 |
Newbie Join Date: Nov 2013 Location: Cameron
| Painting Aluminum
I just ordered the Wraith Three Piece side panel kit from Carter Fab and Machine for my Poison Spyder Wraith. I would like to paint these panel close to the same shade of blue as my old body was. I was hoping to just paint the panels blue and then add some of small decals from the PS website. Are there any tips or special precautions/paints that will give me the best overall paint job? Thanks |
11-20-2013, 02:16 PM | #2 |
RCC Addict Join Date: Jun 2011 Location: Lindsborg
| Re: Painting Aluminum
as with any paint job, prep light sand with a fine paper, clean with thinner (on metals) or denatured alcohol (any surface), and spray you can do a light colored primer if you like, depends on the color you are laying down. if it is dark, probably don't need a primer, if it is light I would probably prime it. |
11-20-2013, 02:33 PM | #3 |
RCC Addict Join Date: Jul 2009 Location: Ontherocks
Along with sanding, a few light coats of self etching primer should help it stick. My painted aluminum beadlock rings held up pretty decently considering my truck that sees a lot of time on the rocks. But hey...rock rash is good:thumbup: Sent from a rock |
11-21-2013, 05:22 AM | #4 |
RCC Addict Join Date: Sep 2007 Location: Hallsville, Tx
Yep as said above, the etching primer is a must to help the paint stick to the aluminum, I found out the hard way.
Painting Aluminum - Similar Threads | ||||
painting aluminum panels | ezee | Axial Wraith | 6 | 02-23-2012 12:02 PM |
Painting aluminum? | Going Up! | Paint and Body | 7 | 01-23-2012 05:46 PM |
Painting Aluminum body panels!! | Mr.Tek | Paint and Body | 3 | 12-05-2011 09:11 PM |
Painting aluminum | Renslipevol | Paint and Body | 3 | 10-16-2008 09:35 PM |
Painting Basics - Painting Tips and Tricks | stampedeproject | Paint and Body | 0 | 03-09-2008 10:39 PM |
