02-14-2015, 04:18 PM | #1 |
Rock Stacker Join Date: Jul 2006 Location: Lincoln
| Stripping a fallen g6 body
Just wondering if it's possible to strip the paint off the axial falken g6 wrangler body? Thank guys
02-14-2015, 05:06 PM | #2 |
Pebble Pounder Join Date: Dec 2013 Location: spring creek
| Re: Stripping a fallen g6 body
#1 got to your local automotive store and pick up some dot 3 or dot 4 brake fluid #2 put some napkins on the inside of the body then put a generous amount of the brake fluid and let it soak for a few hours. #3 you may have to do this process more then once to get all the cracks and crevices #4 tadayy you have a clear body |
02-14-2015, 05:46 PM | #3 |
Rock Crawler Join Date: Mar 2011 Location: USA
I heard some where that you can take it to car wash ,,the one with a HI pressure hand wand ,Hit with the soap setting and the paint flys off ,,The hard part is getting your buddy to hold it while washing paint off,,,
02-14-2015, 06:27 PM | #4 |
I don't think you can strip factory painted bodys?
02-14-2015, 07:26 PM | #5 |
RCC Addict Join Date: Oct 2012 Location: Charleston South Carolina
| Re: Stripping a fallen g6 body |
02-15-2015, 04:45 PM | #6 |
02-17-2015, 05:37 PM | #7 |
Newbie Join Date: May 2008 Location: lake odessa
What does acetone do? Would it make the lexan cloudy?
02-18-2015, 06:08 PM | #8 |
Newbie Join Date: Feb 2015 Location: SoCal IE!
I would be interested to know the answer to this too... Did you try the brake fluid yet? Or acetone? I just bought a scx10 rubicon and would like to paint it tan |
02-20-2015, 09:12 AM | #9 |
Newbie Join Date: Jan 2015 Location: moncton nb canada
i heard the same things about this process before, and i gave it a try with the brake fluid on my sons mighty bull that was in sore need of some updating, but it just did not want to work. it certainly thinned the paint down considerably, but i went over it a number of times and it never really got to any point that i would be able to paint it again. ended up buying a new shell to paint.
02-21-2015, 04:56 PM | #10 |
Quarry Creeper Join Date: Jan 2011 Location: 808 via Reno, Nv.
| Re: Stripping a fallen g6 body Here's what I did to remove the green stripe on my factory wraith body. I didn't like the color scheme and since my rigs are all black and raspberry color, I masked the area I didn't want paint to be removed from. I used a q-tip and a small jar filled with lacquer thinner and applied not heavy to where its dripping but a damp amount to stay wet on the swab. I rubbed back and forth on the areas I wanted to remove the paint from and after a few passes the white backing started to lift revealing the color your removing. "Will require some elbow grease". Now granted the finish wont be totally clear, will have a light haze but was enough for my applications and looked really good to where I could apply the metallic raspberry, then backed the whole panel with white again and walla! A different color scheme that not everyone has. |
Stripping a fallen g6 body - Similar Threads | ||||
Stripping the stock body paint | Coupes4ever | Redcat Crawlers | 10 | 05-24-2013 10:08 PM |
Stripping Paint from a New Bright Body | Tommy R | Paint and Body | 9 | 08-08-2012 05:14 PM |
any body stripping pinions? | murderface | Losi Micro-Rock Crawler | 2 | 11-13-2010 11:44 PM |
stripping paint of hilux body? | euphoricgear | Paint and Body | 7 | 07-19-2010 05:52 PM |
stripping a hard body | NoblesvilleKid | Paint and Body | 13 | 05-01-2007 05:19 PM |
