11-03-2017, 10:43 AM | #1 |
Pebble Pounder Join Date: Oct 2006 Location: Montreal
| Removing paint from plastic?
I bought a used truck and the previous owners painted some of the embossed logos on the plastic parts silver.. It might have been done with a silver sharpie. Is there any way to get this off without damaging the plastic? I prefer the stock look.
11-03-2017, 07:26 PM | #2 |
| Re: Removing paint from plastic?
If it is a hardbody and styrene, lightly brush some Testor's paint thinner on it, wait a few minutes, and wipe or rub it off. If it's lexan, Dot 4 brake fluid.
11-04-2017, 07:17 AM | #3 |
Rock Crawler Join Date: Oct 2009 Location: Upstate NY
Rubbing alcohol usually works on Sharpie, but you can also use a razor blade or fine sand paper and carefully remove the paint. I like to lightly scrape the paint off of my static model Jeep logos and reveal the white plastic underneath rather than trying to paint them white...much easier. A pic of the logos would be very helpful. |
11-04-2017, 07:38 AM | #4 |
91% isopropyl on a small brush. The alcohol will usually remove paint, use a small brush, take your time Hang up and Drive |
11-04-2017, 02:20 PM | #5 |
Pebble Pounder Join Date: Jun 2011 Location: AREA 51
| Re: Removing paint from plastic? |
11-04-2017, 05:05 PM | #6 |
RCC Addict Join Date: Jun 2006 Location: Durham, NC, USA
nail polish remover works
11-04-2017, 05:22 PM | #7 |
Thanks guys! I should have been more clear the paint is on the actual plastic parts of the truck (axles, rx box) I imagine most of the suggestions for hard bodies would apply here too?
11-04-2017, 06:37 PM | #8 |
11-04-2017, 06:59 PM | #9 |
11-04-2017, 07:00 PM | #10 |
| Re: Removing paint from plastic? Dot 4 has Borate added to it, (which is good for your brakes as it raises the boiling point of the fluid, to maintain the brake system), but it basically comes from Borax which is a cleaning agent. Dot 3, Dot 4 and Dot 5.1 are all Glycol-Ether based Dot 5 is silicon based look it up on summitracing.com if you don't believe me Last edited by Mike Flea; 11-04-2017 at 07:05 PM. |
11-04-2017, 07:32 PM | #11 |
Yup DOT5 Hang up and Drive |
11-05-2017, 06:50 AM | #12 |
Whenever I would strip my static models or chrome, I used Castrol Super Clean. I think it's just called Super Clean now and it comes in a purple jug. I recently stripped the chrome off of some Clod rims in just minutes. Make sure to use gloves with it though. I've never used brake fluid, so I can't say how it works. |
11-06-2017, 03:52 PM | #13 |
Ok so I tried everything (alcohol, acetone, lighter fluid, super clean) and if anyone else is wondering the lighter fluid seemed to work best for me. Didn't try the brake fluid since is really nasty stuff that would have been a lady resort if the other stuff didn't work.
Removing paint from plastic? - Similar Threads | ||||
Removing paint | Dtempleton | Axial Wraith | 7 | 10-26-2012 06:13 AM |
Removing old paint.. | PCHILNSF | Paint and Body | 2 | 08-25-2011 01:34 PM |
removing paint | must85 | Paint and Body | 9 | 10-23-2009 09:22 AM |
Removing chrome on plastic wheels, before or after glue up | cruiserkb | General Crawlers | 10 | 12-22-2008 09:02 AM |
Removing paint?? | msd44 | Paint and Body | 20 | 03-19-2008 09:51 AM |
