03-25-2018, 11:18 PM | #1 |
Newbie Join Date: Dec 2017 Location: San Diego
| Body mounting
Hello all....I have a Unimog 1500 hard body that I'm fitting to my SCX10-II and I can't figure out a front mount arrangement for it. I'm trying to avoid having the posts through the hood. Any suggestions would be appreciated. Thanks rick |
03-26-2018, 08:27 AM | #2 |
Quarry Creeper Join Date: Aug 2017 Location: Satan's Armpit
| Re: Body mounting
I'm using rare earth neodymium magnets to hold the lexan body on my SCX10 II. Although I'm using solid magnets, I might suggest using ones that are rings, with the ID big enough to sit over the top of the post where the body clip would go. Glue one to the body, and one to the posts, and the rings will help the body self align when you place it on top. You will need use the body posts at lower postions, of course. Some have used Velco strips to hold the body, but I might suggest trying 3M's Dual Lock strips. It looks like Velco, but will hold better, even when wet. |
03-26-2018, 09:56 AM | #3 |
| Re: Body mounting
I've also had success using a good, quality (3M) self adhesive velcro. It's completely invisible as far as mounting and surprisingly strong. I've been running a Yota hard body this way and have had zero issues.
03-27-2018, 09:35 PM | #4 |
| Re: Body mounting
Thanks guys.....I ordered a set of magnet mounts, and I picked up a 2 types/brands of Velcro to try. Also picked up an idea about hinging the cab from the front. all are easy to try without tearing up the body....thanks again
06-05-2018, 10:19 PM | #5 |
Rock Stacker Join Date: May 2018 Location: Los Angeles
| Re: Body mounting
Velcro works me. 3m truck weight is about 8 pounds.
06-10-2018, 12:15 AM | #6 |
I wanna be Dave Join Date: Feb 2009 Location: Detroit
| Re: Body mounting
Scx10.2 rails. I used 2 existing holes in the body for some c channel aluminum to bolt through and slid the rails in my cut out spot. Height adjustment could be made using a piece of flat aluminum. In the back i used offset body posts from a different brand and some long revo rod ends. I secured the body mount througgt the bed. My spare tire covers up the hardware somewhat. I hope this helps. It beats velcro and magnets. Sent from my LGMP260 using Tapatalk |
06-10-2018, 07:53 AM | #7 |
| Re: Body mounting
It's nice to get all these different ideas......outside the box type of thinking. Thanks to all!!! |
Body mounting - Similar Threads | ||||
Body mounting? | Synister_Intent | Paint and Body | 5 | 06-27-2016 11:53 AM |
Mounting a Hilux body without body clips? | OrangeTJ | General Scale Talk | 8 | 11-06-2013 06:51 AM |
body mounting | theloudone | General Crawlers | 3 | 03-04-2012 07:22 PM |
Body mounting???? | flyingrc | Paint and Body | 6 | 02-26-2012 04:36 PM |
mounting a body | andypants | Newbie General | 5 | 01-14-2010 05:21 AM |
