Go Back   RCCrawler Forums > RCCrawler General Tech > Paint and Body
Thread: Filling shell/body section
Old 12-10-2018, 10:27 PM   #1
Default Filling shell/body section
Hey
Iv got a losi night crawler bare shell that I'm going to use. It has a section in the front window for a roof mounted light bar. I'm not running a light bar on my crawler so I'm wanting to fill the sunken section so its flush with the rest of the windscreen and then make a black strip sticker to run across the top 5mm to 8mm of the windscreen. Sorry I can't post pics as haven't got any way of doing so.
I'm thinking of just taping around the sunken part at top of the windscreen and using shoe too to fill the hole/sunken section then I'll have nice clean edges when removing the tape so it won't effect the internal area that I'll paint afterwards.
I know bout wetting your finger and smoothing the shoe too for a neat finish. But I wanted to check if there is a better way of doing this job?
I'm thinking body filler or epoxy will be too hard/brittle for the lexan body and will eventually crack.
Any advice will be appreciated.
Snyds
snydas1987 is offline   Reply With Quote
Old 12-11-2018, 12:41 AM   #2
Default Re: Filling shell/body section
I meant using shoe goo.
Stupid spell check.
Is this the best option?
Old 12-11-2018, 01:54 PM   #3
I would shoe goo with a small bit of drywall mesh in it. If you do it as a few layers it will be smoother, let it dry and shrink then it will sand
mikemcE is offline   Reply With Quote
Old 12-11-2018, 06:15 PM   #4
So you can sand shoe goo?
Also can you use car plastic bumper filler? Its another option iv seen.
Old 12-12-2018, 05:30 AM   #5
sorta.......it wont ever be SMOOTH but OK.
The bumper fillers are $$$ and heavy, not sure if id try them on lexan
Old 12-21-2018, 07:04 PM   #6
Hal
I have had pretty good luck with a mix of superglue and baking soda. Fill hole with baking soda and drip superglue on it. It hardens realy fast and so far for me has been pretty durable. I have not tried it but a friend of mine says if you use the tire super glue ( black ) it stays somewhat flexible. I think the black tire glue has rubber dust in it, I use it for tire shut and cut and tire repair. I dont know how it will sand or hold paint. Just a thought. Let us know what you do, there are always people looking to do some type of mod or repair on lexan. Good luck
Hal is offline   Reply With Quote
Old 12-21-2018, 10:35 PM   #7
THIS
https://youtu.be/Ji0lCBlNZC4
Shinchu is offline   Reply With Quote
Filling shell/body section - Similar Threads
2 crawler,4 body shell?how many body shell mike_like Chit Chat 7 11-26-2014 11:42 PM
Need help filling hole's in a hilux body 4ufearthis Paint and Body 10 12-18-2011 08:17 PM
Filling Hard body plastic holes GeoffSFAs10 General Scale Talk 7 03-07-2009 03:24 PM
Filling holes in a hard body Rat1 Paint and Body 8 11-23-2008 03:59 PM
Filling body cavities tinsoldier Paint and Body 4 06-06-2008 02:43 PM
