Go Back   RCCrawler Forums > RCCrawler General Tech > Paint and Body
Thread: Window Mask Residue HELP!!!
Old 03-28-2021, 07:27 PM   #1
Default Window Mask Residue HELP!!!
Hey guys, finished up spraying my new lexan cab for my rig. When I pulled the masks off. White axial window masks. I had some sticky residue left behind on two headlight lenses and one spot on the windshield. Anyone have a trick up their sleeves to remove it? Really don't want to mess up this paint job or my lenses. Thanks in advance for any help! It's greatly appreciated!!!
AnimalHippie is offline   Reply With Quote
Old 03-28-2021, 08:28 PM   #2
Default Re: Window Mask Residue HELP!!!
Try a piece of masking or duct tape. Stick it on and pull off repeatedly to try to pull off the crud.
Sniper4370 is offline   Reply With Quote
Old 03-28-2021, 08:53 PM   #3
CODYBOY's Avatar
Same as what he said!!
CODYBOY is offline   Reply With Quote
Old 03-29-2021, 12:55 AM   #4
WD40 ... great for removing glue residue.
tuxstang is offline   Reply With Quote
Old 03-29-2021, 05:42 AM   #5
Thank you guys! I will give that a shot when I get to the house this evening.
Old 03-29-2021, 07:34 AM   #6
Maybe try a Q-Tip with a little bit of rubbing alcohol.
GA Dawg is offline   Reply With Quote
Old 03-29-2021, 09:37 AM   #7
Whatever you do, don't use acetone!
Alcohol or oil should work nicely..
QuesoDelDiablo is offline   Reply With Quote
Old 03-29-2021, 10:07 AM   #8
Naphtha on a q-tip
Bob_in az is offline   Reply With Quote
Old 03-29-2021, 06:40 PM   #9
Thank you again guys!!! The gorilla black duct tape did the trick!!! Now I can get the lenses smoked and start building light buckets. Can't wait to get this thing finished up!!! Super Stoked!!!
Old 03-29-2021, 06:57 PM   #10
Look forward to seeing it.
Window Mask Residue HELP!!! - Similar Threads
What do you use for window mask? DukeMinnix Paint and Body 7 01-22-2018 11:55 AM
window mask dkchance74 Paint and Body 2 02-03-2015 10:11 PM
Window Mask help. eemmaaxxxx Paint and Body 5 08-04-2011 12:19 AM
window mask?? mudhunter Paint and Body 8 02-17-2007 12:59 PM
