Go Back   RCCrawler Forums > RCCrawler General Tech > Paint and Body
Thread: Epoxy reinforcement?
Old 12-02-2021, 10:20 AM   #1
Default Epoxy reinforcement?
I installed a plastic printed fender hub inside of my RC4WD hard body using plastic cement but am wondering if anyone can suggest a way to reinforce this?
Jackson233 is offline   Reply With Quote
Old 12-02-2021, 12:05 PM   #2
Default Re: Epoxy reinforcement?
Drywall mesh tape and shoe goo. Let set overnight and it’s done
Epoxy will dry lumpy so its like bondo, sanding time if the looks are an issue. The drywall tape inside the wheel wheels can be painted to hide
Hang up and Drive
mikemcE is online now   Reply With Quote
Old 12-02-2021, 02:19 PM   #3
Thanks Mike, I even have that combo kicking around so I'll give it a shot.
Old 12-03-2021, 05:51 AM   #4
In what plastic is it printed ? If it's ABS, model glue should be a good bet, it'll melt both surfaces together, you'll have hard times getting a better bond.
tuxstang is offline   Reply With Quote
Old 12-10-2021, 04:25 PM   #5
I would recommend E6000 over Shoe Goo. They are very similar in terms of holding parts together and curing time with one major exception. E6000 is self-leveling meaing it will flow out to a smooth finish which for your application will make a much nicer looking finished seam.
Inspector86 is offline   Reply With Quote
Old 12-11-2021, 08:29 AM   #6
That can be a plus or minus. It will puddle if not set correctly for curing.
Hang up and Drive
Old 12-11-2021, 07:41 PM   #7
Hang up and Drive
You do have to be smarter than the glue!
Old 12-11-2021, 09:38 PM   #8
I wasn’t, used 6000 to finish a side tear that I’d started with goo. Added some 6000 to the sides, sat it level.had two blobs on the floor !
That’s the difference in those two, but they both work well if used correctly
Hang up and Drive
Epoxy reinforcement? - Similar Threads
Question about body reinforcement Elmo Paint and Body 9 11-11-2014 06:54 PM
Body reinforcement Phoenix76 Rally 5 08-28-2013 10:20 PM
chassis reinforcement samguan General Crawlers 6 06-05-2010 08:59 PM
wheel narrowing reinforcement. muddeprived Tires and Wheels 12 06-19-2007 02:44 PM
rear link reinforcement SlammedMini469 General Crawlers 1 01-07-2006 03:37 AM
