11-04-2014, 12:23 PM | #1 |
Quarry Creeper Join Date: Dec 2010 Location: Jacksonville
| xv01 pro chassis
i got one on order. I got a Subaru wrx 190mm body on order too. will i need special body posts for this body? also got a 23t pinion 48pitch robinson racing. motor is tba Esc is Castle MMP or Sidewinder (the sidewinder in my sc10 4x4 but i never use it its paired to a 4000kv motor but its a 5mm shaft. I d need 23t mod8 gear for it if i use it) also.. hd belt and slipper clutch.. |
11-04-2014, 11:11 PM | #2 |
Gettin’ back on the horse Join Date: Feb 2006 Location: Hoonsville
| Re: xv01 pro chassis
Sounds good, but the XV01 comes as a .6 mod pitch, not 48 pitch. If you get the slipper set that will then convert the car to 48 pitch and then you will be solid. Edit: I see you are getting the slipper, so carry on. |
11-05-2014, 08:25 AM | #3 |
Rock Crawler Join Date: Apr 2013 Location: Buena Vista
you shouldn't need any special body posts...
11-05-2014, 08:33 AM | #4 |
$80 worth of upgrades and i dont even have the car yet.. i love this sport!
11-05-2014, 09:03 AM | #5 |
Quarry Creeper Join Date: Mar 2011 Location: Universal City, TX
Sometimes I wonder if it isn't just cheaper in the long run to purchase these cars (chassis) as individual parts. Buy all the hop ups you're likely to buy, then buy the rest of the plastic parts ala carte, and stainless hardware to put it together. Then all you need is a manual which (I think) is available as a PDF from the tamiya website. Tappa who? |
11-05-2014, 09:13 AM | #6 |
its using Ty's post as a Rally Build Bible.. and saying.. ok. Basic Kit + HD Belt + Slipper Clutch seems to be the best novice upgrade. Run the car as is til you break parts.. Upgrade with Yeah Racing aluminum as Phase II.. and see what else will need upgrading based on his post. I created such a thing on our board for the rally thing: XV01 Build Sheet |
11-05-2014, 10:27 AM | #7 | |
| Re: xv01 pro chassis Quote:
11-06-2014, 03:16 PM | #8 |
So the Pro comes with All Terrains vs the Rally Blocks... not cool..
11-10-2014, 07:40 AM | #9 |
Ty said something about upgrading the blocks.. the steering blocks? to aluminum? is that what he was refering to?
11-10-2014, 08:42 AM | #10 |
| Re: xv01 pro chassis |
11-10-2014, 10:03 AM | #11 | |
Tappa who? | |
11-10-2014, 12:52 PM | #12 | |
| Re: xv01 pro chassis Quote: is it X2? or just order one? looking at PDF.. i looked like the one in the front. So i ordered 1. Thanks TY Last edited by jeepgeek2002; 11-10-2014 at 01:04 PM. | |
11-14-2014, 06:34 AM | #13 |
So the slipper clutch, toe thingy, new belt, body all came in.. all i need to get now is the car.. its arrived and i pick it up today Esc is HobbyWing 60a motor a 3800 4 pole castle servo is savox 1251mg I have bec from too if needed. now to build.. |
11-19-2014, 05:46 PM | #14 |
Rock Crawler Join Date: Sep 2013 Location: New Orleans
| Re: xv01 pro chassis I was under the impression the slipper clutch and the HD belt came with the pro kit. If not, I'm sorry, fairly new to the rally scene.
11-20-2014, 08:41 AM | #15 |
looking at the pdf: http://www.tamiyausa.com/pdf/manuals/58526ml.pdf shows direct drive for the spur (no i didnt get it yet.. its still at the LHS on lay away..) |
11-20-2014, 09:08 AM | #16 | |
11-20-2014, 12:09 PM | #17 |
Ty said get 1XJ aluminum blocks for it too.. as it adds to less failure. i didnt realize there are 2 of these needed .. front and rear. plus the small toe blocks as well for the front. the front small toe are about $30 on ebay the larger blocks are about $11 ebay |
11-20-2014, 01:03 PM | #18 | |
11-20-2014, 01:07 PM | #19 |
i have a 3800 castle i picked up for a steal.. and a hobby wing 60amp esc.. we created a rally course and i plan on running it there.. i have a Tacon/LC Racing rally car right now.. works great.. great basher.. 4500 kv brushless shaft driven car.. i have jumped tripples and doubles on the short course track and drove it on the oval .. still have not broken a single item other than the body.. great cheap car ~$189 rtr The XV01 will be more to scale of 1/10 and is more a rally car than a beat on it car.. i ll post pictures when i get it in a race here |
11-20-2014, 01:37 PM | #20 | |
xv01 pro chassis - Similar Threads | ||||
The-Gamer's XV01 | the-gamer | Rally | 2 | 06-06-2014 01:37 AM |
Which Rally Car?? XV01 or WR8 FLux | Phoenix76 | Rally | 30 | 10-29-2013 05:20 PM |
