Go Back   RCCrawler Forums > Miscellaneous > Rally
Thread: What tire inserts do you use for larger rally tires?
Old 05-05-2015, 10:38 AM   #1
Default What tire inserts do you use for larger rally tires?
I have a couple different sets of tires that I like for my rally car. One problem I have is that many touring car foams don't fill out a rally tire as much as I would like. Do you guys have a foam preference that works with a slightly larger rally tire? Thanks.
1967Typhoon is offline   Reply With Quote
Old 05-05-2015, 01:21 PM   #2
Default Re: What tire inserts do you use for larger rally tires?
Tamiya 53156 Hard Inner Tire Sponge
CheapTwin is offline   Reply With Quote
Old 05-05-2015, 01:53 PM   #3
Those look OK. They don't seem very thick though. I'm not sure they would fill out my tires.
Old 05-05-2015, 02:47 PM   #4
What tires are you using? The 53156 should work. I'm pretty sure that's what most use in their rally blocks.
bvrc is offline   Reply With Quote
Old 05-06-2015, 08:49 AM   #5
I'm using HPI pirelli tires. I ended up turning 2 rear 1/10th buggy foams into 4 inserts that fill out the tire really well. I think this might be what I am after, and many racers in my area pitch the open cells that come with buggy tires. Can't beat free!
What tire inserts do you use for larger rally tires? - Similar Threads
4.18 tires and larger, what are you doing about tire rub? kurtus RC4WD Trail Finder 2 10 07-22-2012 04:39 PM
Losi Claws Vs larger tire Vs CG Mr Hyde Tires and Wheels 20 03-09-2009 11:47 AM
Larger wheel and tire issue..need help daddybrock Axial AX-10 Scorpion 7 08-28-2008 07:04 PM
narrowing wheels make tire larger. norcrawler Tires and Wheels 6 07-16-2008 01:03 AM
New Tire Inserts Available!!! kreepykrawler HPI Wheely King 4 06-06-2007 04:52 PM
