04-14-2012, 04:43 PM | #1 |
RCC Addict Join Date: Oct 2009 Location: Nanaimo, BC (Vancouver Island)
| 4.18 tires and larger, what are you doing about tire rub?
Just got my set of rc4wd 1.55 rock stompers(feel twice as stick as the mud trashers) in and I'm running the front shackle flip mod, my tires rub really bad on compression while turning on the cab side(not the front bumper side) of the lower fender wells. So my question to you guys running 4.2" tires or close to it, what are you doing to allow your tires to clear. I have ordered a ubolt set for front and rear because I was told it will allow me to move my axles on the leafs which would allow me to get the wheels situated in the wheel wells better to deal with the larger tires. What else can be done, can I run the thin hexes cause I know some guys are having issues with those as well since they sit too low in the hubs on the 1.55 wheels. Please, any thoughts here would be very helpful. Kurt |
04-15-2012, 01:28 AM | #2 |
Newbie Join Date: Dec 2010 Location: Germany
| Re: 4.18 tires and larger, what are you doing about tire rub?
Hi Kurt, not helpful for you, but I'm having this issue even with the stock wheels (and stock shackle positions). The tires rub on the front lower corner of the fender. I already moved the axle 3mm backwards but still too wide a track even with the thinner hexes. Are all those great TF2s here having this problem or do you run them so stiff the tires don't even get close to the body ?
04-15-2012, 11:25 PM | #3 |
Quarry Creeper Join Date: Jun 2011 Location: butler pa
i used the briuser style shackles raised the front enough to clear
04-16-2012, 12:29 PM | #4 |
I wanna be Dave Join Date: Dec 2006 Location: In Cali.
Will have something very soon to help a small amount with this issue. So you can run a little taller tires.
04-16-2012, 12:48 PM | #5 | |
| Re: 4.18 tires and larger, what are you doing about tire rub? Quote:
Ps should I hold off on a bruiser shackle set or can u say when it might be released? | |
04-16-2012, 01:13 PM | #6 |
Moderator Join Date: Jan 2004 Location: chicago
i got the ublot kit and moved my axles fwd on both the front and rear. rear shocks required some spacers on the axle and chassis so the shock bodies wouldnt hit the ubolt plates on compression. |
04-16-2012, 01:39 PM | #7 |
| Re: 4.18 tires and larger, what are you doing about tire rub? Yeah I have my u bolt kits on order but they were Bo on me so now we wait, in the mean time I already added 6mm spacers to the upper and lower along with the provided 2mm spacers on the bottom for the rears. Thx man
04-17-2012, 11:47 PM | #8 |
RCC Addict Join Date: Sep 2007 Location: Western ND, Bakken central
| Re: 4.18 tires and larger, what are you doing about tire rub? |
04-17-2012, 11:55 PM | #9 | |
| Re: 4.18 tires and larger, what are you doing about tire rub? Quote: | |
07-21-2012, 05:28 PM | #10 |
$30.00 + shipping? They must have bumped their heads! |
07-22-2012, 04:39 PM | #11 |
Newbie Join Date: Jul 2012 Location: Millersville
I used the 8mm wide hex hubs from a Traxxas slash 2wd. Worked perfect with 1.9 Pro 10's from Rc4wd and TSL SX's
4.18 tires and larger, what are you doing about tire rub? - Similar Threads | ||||
XR10 Tire and spring rub? | morpheus_tn | Axial XR10 | 21 | 01-31-2012 08:32 PM |
tire rub | ax10newguy | General Crawlers | 10 | 05-08-2010 12:32 AM |
tire rub...wheel offsets? | 73fordhighboy | Duratrax Cliff Climber | 10 | 10-20-2009 01:27 AM |
slingshot, revo shocks, tire rub problems?? | robchas | Axial AX-10 Scorpion | 15 | 05-15-2009 02:46 AM |
Axial tire rub | alpinehyperite | Newbie General | 6 | 06-10-2008 08:02 PM |
