03-06-2016, 03:05 PM | #1 |
Newbie Join Date: Mar 2016
| XV-01 e-ring won't fit on middle shaft
The e-ring groove on the middle shaft (BA19) that holds on the outside pully is covered up by the pully itself. I can't install it. This is for both the front and rear gearbox. It's like just a millimeter shy of working. Any ideas? Oh, I also just noticed in the margin of the instructions that "files and drills will be used for fine adjustment". Do I just lightly file on the outside of the pully until I can see the e-ring groove? Thanks, Todd Last edited by todd_c; 03-06-2016 at 03:10 PM. Reason: Saw something new |
03-06-2016, 08:30 PM | #2 |
| Re: XV-01 e-ring won't fit on middle shaft
Finally got it. Ended up lightly sanding the outside of the pully to help expose the e-ring groove and then used an awl to make a slight concave impression in the plastic NN4 spacer on the other side so that I could fit in the cross pin.
03-07-2016, 04:37 PM | #3 |
Rock Stacker Join Date: Dec 2015 Location: toronto
i had the same problem when i was building the XV-01. i dont know if it is just a bad luck, or just design flaw. i did not have a sand paper, so i had to use a sharpening rock! |
XV-01 e-ring won't fit on middle shaft - Similar Threads | ||||
Servo output shaft o ring. | 65BAJA | Electronics | 6 | 07-17-2013 08:43 PM |
Need Maxx shaft help, output doesn't fit driveshaft..? | matt889 | Axial AX-10 Scorpion | 6 | 03-07-2013 12:02 PM |
Drive shaft ring? | mr lee | Axial SCX-10 | 8 | 08-14-2011 03:57 AM |
tamiya prop shaft e-ring | sierradmax | 2.2 Scale Rigs | 0 | 12-14-2008 05:53 PM |
