| | #1 |
| Picky Fab'r/Acetal Junky ![]() Join Date: Jul 2006 Location: Arizona Desert/AJ
| Got started on it this weekend. Don't really have a whole lot accomplished yet...but there's enough to get the thread started I suppose. One thing about it already is how wide it is. Due to being a shafty, I have the trans/motor/dig assembly that I need to stuff in between the chassis plates. I needed to use a wider skid plate...so instead of making one..I took the easy way out and used the HR skid meant for an AX. :-P I had some issues with it being so wide and getting the chassis in the correct orientation and ground clearance...but after trying several different shock setups (I have what seems to be an enormous collection of shocks I'm using my favorite set of shocks...the Proline Powerstrokes in a half droop setup. They are 115mm fully extended, but using only a main spring and no tender (they come as a dual rate), they sit static at about 88mm. With them set up like this, I have about 15mm of compression & 26mm of extension available from static. Should work well with the torsion front. The front toelinks for the torsion connection are 70mm. I'm waiting on some high clearance lower links before I go any further. I want to get them installed before I make the uppers. I will be building this rig almost at the same time as my mini-clod...and they are going to be "negatives" of each other...and I have a cool idea for the bodies based on that Here's a couple other tidbits: MM ESC Castle BEC HH Puller 7T DNA dig 5955TG (steering) 5645MG (dig...overkill I know) Lot's of little upgrades I am forgetting... BTW...please forgive the pics this go-round...I was too lazy to clean off the whole bench just to set up the lightbox :-P ![]() ![]() |
| Sponsored Links | |
| | #2 |
| Quarry Creeper Join Date: Jan 2009 Location: El Cajon San Diego
| Looking good. I'll be watching this. |
| | #3 |
| ... Join Date: Sep 2005 Location: USA
| Thats a Nice start? Are your Front 70mm Links mounted on the inside of the chassis or outside? |
| | #4 |
| They are on the inside. I figured they'd be better off matching the shocks in the rear. Oh, and those weak looking toelinks are going to go away. I'll be remaking those from black acetal and Revos...same procedure that the uppers will be. |
| | #5 |
| RCC Addict Join Date: Jul 2008 Location: Sin City
| | #6 |
| | #7 |
| RCC Addict ![]() Join Date: Sep 2005 Location: Tempe, AZ
| Very cool John!! I will be intersted to watch this as well as your miniclod. I am waiting for a chassis right now for my miniclod. |
| | #8 |
| I'm interested in see how it works all out. I designed the Chassis's for MOA's, but set it up where the Common Ax-10 Skid would built right up. |
| | #9 |
| Any updates? Also why isn't this in the Ax-10 section? |
| | #10 |
| Nothing further yet. Waiting on a set of lower links so I can make the uppers...and I'm still debating and taking forever to decide...on a couple more parts to finish 'er up. I just posted it up in General...but I guess it could have gone in Axial. If a mod wants to move it...I won't be too upset |
| | #11 |
| Small update... I will soon be asking a mod to change the title of this thread. The Axials are getting ditched from this project and a new set of Bully's are going to be used instead. I think I'll be much happier overall with this rig by running the MOA's. |
| | #12 |
| I think you'll be a happier that with your new axles and this chassis. Still, I would have liked to see how your build would have went had you stuck with shafted axles. |
| | #13 |
| Damn now ill have to start another one and make a shafty. You will like the bullies though. Once the Ti shafts are released they will be indestructable! Post up if you have any questions on them. |
| | #14 |
| Here's an update. Like I said before, I ditched the Axials and decided on Bullys. These axlea are sweet, and I think will work much better on this rig. Took alot of playing around with different rod ends, different length bent and straight links, and different shock/toe link lengths to get it all working and fitting right. Ended up with a collection of rod ends including Revos, Jatos, and Kyoshos I pushed the rear link mounts outward on the axle to both help with shock clearance on the axle gearbox...and to get the links around the gearbox and motor. Have just enough clearance to the tires and wheels with it like this. The biggest problem now is the steering. As seen in the last pic...the steering throw is horrible. Not sure how to gain more unless I use wideners or a wheel with less backspacing. The links are as close to the gearbox as I can get them. The truck sits right now at 9.625" width outside the Rovers. I could afford to gain a bit of width...but I love these wheels. This only leaves me with the option of wideners. There are the Gmades that add 15mm to each side...should be enough without being too much. Anybody else have any other options to fix the steering issue? ![]() ![]() ![]() Last edited by Offroader5; 04-12-2009 at 01:07 PM. |
| | #15 |
| I wanna be Dave Join Date: Jan 2009 Location: 801-Utah
| I like the way you used the offset rod ends on the rear uppers! good thinking!! |
| | #16 |
| | #17 |
| On the steering the wheels will always rub a little on the bullies. With the round lowers you will be fine (with the kamikaze lowers it sounds like it has gas when it rubs, lol). There will be some play in the lower links, twist them in the rod ends until the play will let them hit the gearboxes. This will give you a little more clearance for the front tires and more steering. Let me go take some pictures of mine to show you. |
| | #18 |
| | #19 |
| RCC Addict ![]() Join Date: Sep 2007 Location: Westland, MI
| Looks good. |
| | #20 |
| Rock Crawler ![]() Join Date: Aug 2007 Location: oak harbor
| good work diggin all of offroader5's builds super cool clean building. |
| Thread Tools | |
| Display Modes | |
