Thread: Trailfinder 2 improve your performance
Old 03-02-2012, 04:51 PM   #1
Talking Trailfinder 2 improve your performance
Hi guys,
just started to build my TF2. I did not like the position of the Motor, much to high...
So I thought about flipping it down. Vou need to cut one of the posts from the Motorplate and it fits perfekt. The front Axle must have been made for this Mod.
On the picture the chassis is nearly in a drop-setup and there is still a lot of space between Motor and Axle :-)
Now the Chassis is ready to compete I am loving it :-)
--freeride-- is offline   Reply With Quote
Old 03-02-2012, 05:46 PM   #2
Sinking with the ship
1BadJeepBruiser's Avatar
Default Re: Trailfinder 2 improve your performance
good mod if you are competing and looking for a low COG, but I think it hanging down kind of kills the scale look.
Old 03-02-2012, 05:53 PM   #3
Pretty cool
Die-Laughing is offline   Reply With Quote
Old 03-02-2012, 05:55 PM   #4
Does it limit articulation..? Looks like you would lose some wheels travel. Just wondering.
Rivas Concepts is offline   Reply With Quote
Old 03-02-2012, 06:27 PM   #5
looks to me like it would limit the up travel of the axel...I do like the lower CG aspect tho!
whiplash is offline   Reply With Quote
Old 03-02-2012, 06:38 PM   #6
I see in the picture you have the suspension at almost full compression and it doesnt hit the motor. But what if you fully lift the drivers front wheel and lower the passenger front. Make sure to check clearances when you articulate the axles.
Propane is offline   Reply With Quote
Old 03-02-2012, 10:57 PM   #7
Maybe its just me but if I was really worried about performance I would remove the heavy ass 2spd.. You could do that and not ruin the look..
sloppy is offline   Reply With Quote
Old 03-03-2012, 01:32 AM   #8
Why do you think it ruins the look, the Motor is still a little higher than the trany is, looks like a real Engine from the side. Paint it black and you won't even notice the Mod when the car is assembled.
I just put it together, I won't run the Car in this setup. But what you can see is that there is a lot of space even in the drop setup. The dampers are the limit to the articulation and the suspension in any case.
If you take out the dampers the motor hits the axle the same time the driveshaft hits the trany, its perfekt even with shorter dampers.
Old 03-03-2012, 07:10 AM   #9
Old guy
ROCKEDUP RICKY's Avatar
I like it, but it looks like you'll have to keep your steering under the leafs. Is the tranny in the stock position.
ROCKEDUP RICKY is offline   Reply With Quote
Old 03-03-2012, 09:48 AM   #10
The Trany is in the stock position. Yeah the stearing will be a little tricky. I will take 4mm stealtube lets see if a bent one fits or if I need to go under the leafs.
Old 03-03-2012, 10:49 AM   #11
Old guy
There might be enough room to make a bent one to go around the motor and above the leafs.
Trailfinder 2 improve your performance - Similar Threads
Trying to improve my MRC 86 Iroc Losi Mini-Rock Crawler 13 01-23-2010 12:22 PM
Help me improve my steering Tomy Axial AX-10 Scorpion 20 12-01-2008 09:08 AM
How to improve my crawler setecastronomy Tamiya TLT Crawlers 4 06-17-2008 02:36 PM
How to improve downhilling? Philistine Axial AX-10 Scorpion 7 03-11-2008 10:38 AM
A List of Simple Modifications to Improve Performance alterchristopher General Crawlers 24 12-08-2005 06:51 PM
