07-04-2012, 09:39 AM | #1 |
Rock Crawler Join Date: Jan 2010 Location: Pacifica, CA.
| Stock Driveshaft Question
We all know the stock driveshafts are a problem and I was wondering if this was a manufacturing problem or did they design them to twist on the spline to prevent damage to your gears? Others have reported that they are the same as the Gelande driveshafts but with lower quality plastics. I am currently using some stock SCX-10 driveshafts and they are holding up just fine. |
07-08-2012, 07:25 AM | #2 |
Quarry Creeper Join Date: Apr 2012 Location: Missouri
| Re: Stock Driveshaft Question
Yes the newer 6-spline shaft twist easy then won't telescope, think that's bad the older version was so sloppy on outputs, bind would ussually cause breakage. It's a smart/tactical move, there giving a truck to general public without a clutch,so something has to give, also starts the hop-up process which we all know will overshadow the cost of any truck 3X over. Been using same 6-pack of stampede shafts for 5yrs... Last edited by RiceBurner; 07-08-2012 at 07:27 AM. |
07-12-2012, 08:47 PM | #3 |
Pebble Pounder Join Date: Jan 2011 Location: Peace and Quiet
I bought this set, and it seems as the rear shaft is way too long. http://www.amainhobbies.com/product_...-CVD-Kit-SCX10 Anyone have any suggestions? |
07-14-2012, 12:04 AM | #4 | |
Pebble Pounder Join Date: Oct 2008 Location: mid state
| Re: Stock Driveshaft Question Quote:
i have the mip drive shafts on my tuber crawler and since it has a dig unit i had to have the rear one machind down to the correct length. it can bedone but the metal they are made from is super hard. the guy who did mine chucked it up in a lathe. | |
07-14-2012, 03:00 AM | #5 |
Pebble Pounder Join Date: Jun 2012 Location: Derby, UK
Hum that's not good news - I've got those waiting to go on mine too - I read elsewhere that scx shafts were a straight swap ...
07-14-2012, 04:00 AM | #6 |
RCC Addict Join Date: Oct 2011 Location: Brighton UK
Don't even bother fitting the stock ones, order junfacs or the likes the same day you order the truck! Suggest not getting rc4wd shafts as then your lining their pockets for this oversight, just out of principle. |
07-14-2012, 05:56 AM | #7 |
Thanks for the advice Bill - I thought I'd done that, but now I'm worried I've got the wrong set. There are plenty of Junfac shafts to choose from so I need to get this right without wasting more money. Looking at this page two different length stock shafts are available. Trail Finder 2 Parts - Drivetrain I'm guessing the front and rear stock shafts are different lengths - is that correct? The MIP shafts for the scx10 that K1llerRC and I have bought are both the same length, 105mm at their shortest. If the TF2 stock rear shaft is shorter this would explain his problem. |
Stock Driveshaft Question - Similar Threads | ||||
Stock Losi Driveshaft Pin Fix | Crawl_Before_Walking | Losi Mini-Rock Crawler | 4 | 04-08-2010 05:11 PM |
Stock Driveshaft fix | Positronic | Axial AX-10 Scorpion | 8 | 01-28-2009 07:35 PM |
Strengthening the stock driveshaft | 72Blazer | Axial AX-10 Scorpion | 10 | 05-07-2008 08:33 PM |
Stock tlt-1 driveshaft stretch | buddha | Tamiya TLT Crawlers | 2 | 03-03-2007 09:30 AM |
