Thread: axle upgrade options
Old 12-09-2012, 12:47 PM   #1
Question axle upgrade options
im looking to upgrade from the yota axles but i dont have the $250 for a set of any rc4wd axles that will bolt right in. what other options do i have. i have a set of ax10 axles that almost fit. has anyone here just experimented with this.
im trying to upgrade for strength since ive already had to rebuild my stock tf2 yota axles 3 times. i will say i use mine hard. but there is nothing but extreme rock (even on our easy trails) and i use this truck for our local g6 events too. it get run really hard.
rock_starr is offline   Reply With Quote
Old 12-09-2012, 12:59 PM   #2
Default Re: axle upgrade options
The new vanquish pro rock 60's would be fudging awesome
Jeepfixer1 is offline   Reply With Quote
Old 12-09-2012, 01:19 PM   #3
yeah they would be but thats $$$
Old 12-09-2012, 02:08 PM   #4
If you wanna play like a sport, you gotta pay like a sport
The Yota axles are pretty awesome, not sure why you'd need to change.
tozrovr is offline   Reply With Quote
Old 12-09-2012, 02:14 PM   #5
strength is why im wanting to replace. out here we go hard. and im the only person who runs a tf2 with the scx10s out here. i show them up on the tighter stuff but then they turn that on me on other situations.
Old 12-09-2012, 02:15 PM   #6
if you wanna experience what im talking about with the extreme situations we encounter we would be glad to have y'all come run with us.
Old 12-09-2012, 02:18 PM   #7
My point is that with properly shimmed gears and maybe some XVD's I can't see how you'd nuke stuff unless you're running gooey 2.2's on 3S with zero regard.
I lust after a set of the new GCM A-13 Metalhead axles...mmmmmmm BURLY and scale, but some cash.
Maybe some cut down wraith axles?
Old 12-09-2012, 02:29 PM   #8
im running pitbulls w/ a tekin 35t hand wound. im on my now third set of gears shimmed properly. everytime i go to order xvds they go out of stock. 7 runs now and i like the advantage of the narrow width but EVERY time i take it out i have an axle issue. and im sure im one of only a couple who use there tf2 as hard as i do.
just curious but what kinda terrain do you run yours in.
Old 12-10-2012, 12:43 PM   #9
i think they are direct fit from the axial ax10, anyone knows for sure?
ektoz is offline   Reply With Quote
Old 12-10-2012, 01:58 PM   #10
I tried it already. To do it the leaf springs need to be moved outboard
Old 12-10-2012, 04:27 PM   #11
Moderator
badhoopty's Avatar
rcbros and i think gcm sell leaf spring mounts to adapt the axial axle mounting points to the tf2/tamiya highlift width.
badhoopty is offline   Reply With Quote
Old 12-10-2012, 05:12 PM   #12
To put the Axial axles under the TF2 just cut 1/8" thick plate to the correct size. Drill two holes to bolt it to the axles and drill and tap two more holes to bolt the leafs to.
cutlaSS is offline   Reply With Quote
Old 02-04-2013, 08:56 PM   #13
Mines fully linked I'm gonna be trying to put scx10 axles under it once I get the axles In the mail need a little more width than the yota axles if not I'll get some gmade wideners for the yota axles
gears and grease is offline   Reply With Quote
Old 02-05-2013, 06:09 PM   #14
Jeep whore
scale4x4's Avatar
RC4WD has helical cut gears for thr yota axles now.
scale4x4 is offline   Reply With Quote
axle upgrade options - Similar Threads
Gelande chassis issues & upgrade options DRW-FJ40 1.9 Scale Rigs 21 08-21-2015 11:07 PM
Axle Options monsterman Axial SCX-10 7 05-09-2012 10:20 PM
Super Axle Options doors4u Tamiya Clod Buster 12 01-16-2009 01:24 PM
axle upgrade jordanator62 Tamiya Txt-1 and Juggernaut 2 06-17-2004 11:22 AM
