05-12-2013, 11:42 AM | #1 |
Pebble Pounder Join Date: Feb 2012 Location: Newfoundland Canada
| Slipper clutch slipping? Can't figure it out
I know something is slipping on my tf2 it seems like the slipper but I had it all apart and it looked to be on good condition, i put it back together but the tf2 still slips it can barely move. Spur just spins no matter how much I tighten the slipper. Any ideas?
05-12-2013, 12:19 PM | #2 |
I wanna be Dave Join Date: Jan 2009 Location: New Port Richey, FL.
| Re: Slipper clutch slipping? Can't figure it out
Are the pads glazed? Try a new set and maybe a new spring and locknut.
05-12-2013, 12:19 PM | #3 |
Pebble Pounder Join Date: Sep 2010 Location: Hopewell, Pa
Is your servo fully engaging the gears? I know when I first set mine up when I would shift into high gear the servo wasn't moving far enough to engage the tranny.
05-12-2013, 01:50 PM | #4 |
RCC Addict Join Date: Oct 2011 Location: Brighton UK
I fitted some wheels on mine, can't remember but used the shallow hex's by mistake and was actually clamping the rim to the axle, not the hex to the pin. Worth a check |
05-12-2013, 02:12 PM | #5 |
Pebble Pounder Join Date: Oct 2012 Location: Canada
Had similar problem when switching to 3S. Like Johnnysplits said Clutch Glazed, gave 'er a quick scuff and was good to go again
Slipper clutch slipping? Can't figure it out - Similar Threads | ||||
Slipper clutch. Do you need it? | natskiboy | Axial SCX-10 | 7 | 04-20-2012 05:12 PM |
slipper clutch? | bashin calfee | Axial Wraith | 15 | 03-20-2012 03:06 AM |
Slipper Clutch | 322 | Axial Wraith | 3 | 01-15-2012 11:08 PM |
slipper clutch | theclimber | Axial Wraith | 9 | 07-18-2011 09:35 AM |
Slipper Clutch? | xigtc | Axial SCX-10 | 6 | 11-20-2009 01:23 PM |
