02-01-2015, 04:15 AM | #1 |
Newbie Join Date: Feb 2015 Location: Germany
| Problem with the 3 link Panhard kit
Hello, I'm new in this forum and in the scale crawler scene so sorry if i ask stupid questions. And sorry for my bad english! I have a big problem with the front 3link Kit for my trailfinder 2 as you see on the pics. The panhard link and the steering link has the same length. rebounded all is wrong. It looks a bit better when the shocks weight loaded. I hope you understand what i mean and you can see the problem on the pics. The Kit is new. Never drive it I hope someone can help me out. Thx |
02-01-2015, 06:42 AM | #2 |
Rock Crawler Join Date: Jul 2005 Location: Spartanburg
| Re: Problem with the 3 link Panhard kit
Do you have any larger pictures? These are super small, may just be my app though. RC4WD Team Driver*Krawl Off-Road |
02-01-2015, 07:05 AM | #3 |
Newbie Join Date: Nov 2014 Location: Queens NY
Pics are to small.. Im curious to see ur problem. I just finished my tf2 and i have it set with leaf springs now but i have the front 3 link and will install soon. What length shocks are those they look long? I have the 70 wish i would have gone longer.
02-01-2015, 07:10 AM | #4 |
hi, i try to upload bigger pics. A Mod must activate my account first to use gallery and so on. the shocks are 100mm front and rear with custom shock holder front. Last edited by shayin; 02-01-2015 at 07:19 AM. |
02-01-2015, 07:20 AM | #5 |
Post a pic of the shock mount please if u can.
02-01-2015, 07:47 AM | #6 |
till the admin give me the permission. Here is a link to a post were bigger pics are. Trailfinder 2 Problem mit 3 link Panhard kit - 4x4 Scaler auf RC4WD Basis - Rockcrawler.de |
02-01-2015, 08:44 AM | #7 |
RCC Addict Join Date: Oct 2011 Location: Brighton UK
Looking at the pics from your link you have fitted longer travel shocks. Stock length is 70mm, yours look 90mm+ (might just be the picture). If the above is the case, and as you say mid travel (compressed) they seem correct then that is the answer. Imagine if you had a shock that could sit there at 70mm, all looks well, then you extend it and extend it and extend it at some point somethings going to be wrong. Again if the above is the case, either adjust the shocks ride height so it sits at a more realistic height, or limit its internal travel with a spacer. |
02-01-2015, 08:51 AM | #8 |
Quarry Creeper Join Date: Dec 2009 Location: West Alabama
With the longer shocks you will need a longer panhard bar and steering link....or shorter shocks.
02-01-2015, 09:14 AM | #9 |
thx a lot for this info. the front shocks are 100mm but on a custom front shocktower with the same holes like the gelände 2 shocktowers. i try to make longer steering and panhard link. |
02-01-2015, 10:43 AM | #10 |
@northernerbill: is it possible to calculate the right length for the links? |
02-01-2015, 12:21 PM | #11 |
I wouldn't know how to do it on paper but you could remove the panard bar, refit its ball ends, set the ride height how you want it then measure between the ball ends. That will give you your length. Note though the more you jack up the ride height of the car you will shorten its wheelbase so it will look wrong from the side. |
Problem with the 3 link Panhard kit - Similar Threads | ||||
vanquish cms/panhard/link kit | racer | Axial SCX-10 | 13 | 10-14-2014 10:29 PM |
help with panhard mt from vp 3 link kit | cushdog58 | Axial SCX-10 | 7 | 04-03-2014 08:28 PM |
question about 3 Link / CMS / Panhard Conversion Kit | urnot2brightru | Axial SCX-10 | 16 | 03-26-2014 06:30 PM |
