Thread: Upgrading a TF2 RTR
Old 12-21-2016, 05:45 PM   #21
Natedog's Avatar
Default Re: Upgrading a TF2 RTR
Originally Posted by stonecold View Post
since Asiatees is one of our sponsors and I really like their scale D90 phat axles I decided to mount then up.
I then swapped the mounts back since they made the front tires hit the inside of the fenders, then busted out the dremel and chopped off the front lower valance.
Yes I cut the fronts of the fenders off.
Axles look nice, but how do they compare to the original axles? Looks beefy, spiral cut gears included and heavy too. Is it just me or did they widen the track a bit too?
Rust Oleum Satin Paprika and I'm really liking it. I didn't want to go too far from red because I didn't want to have a blue or white body and have bright red scratches showing through.
Very nice color, I almost used that before.
Finished up the paint job, inspiration came from BKcrawlers TF2. Only thing left for the paint is to get some rock rash details…
Looks good with the red and SSD beadlocks.
Old 12-22-2016, 10:35 AM   #22
Default Upgrading a TF2 RTR
The axles have a higher pinion, better turning radius, a bit wider, and the things you mentioned. I had to turn down my dual rates so the tires didn't run the leafs. They're pretty dang nice. Only one gripe is on the rear Axle, the shock mounts is on top instead of the bottom like the original yota axle.
stonecold is offline   Reply With Quote
Old 01-18-2017, 08:59 PM   #23
You had mentioned sanded and primed did you actually sand the body first before priming it..
rustneversleeps is offline   Reply With Quote
Old 01-21-2017, 07:50 PM   #24
I am also doing upgrades to an RTR. Might see if my SCX10 II RTR Axles will work. Picked up a kit SCX10 II only reason I would consider it. Although I would have to get rid of the leaf spring setup altogether and really not sure if the RC4WD 3 Link/4 Link would work on those axles. Starting off doing a Body Lift, replacing ESC (really annoying that with the RTR the ESC has no Lipo Cutoff) and Servo, also going to be running RC4WD 1.9 Baja Claws 4.19".
malickie is offline   Reply With Quote
Upgrading a TF2 RTR - Similar Threads
Winter project baconbits 1.9 Scale Rigs 0 08-06-2016 09:05 PM
Winter project BigDaddy Ed Tamiya TLT Crawlers 5 02-21-2007 11:52 AM
Hopefully winter project savyxer Tamiya Txt-1 and Juggernaut 6 10-29-2005 11:53 AM
