10-18-2019, 10:16 PM | #1 |
Newbie Join Date: Sep 2019 Location: US
| Tf2 3 link w pan hard steering issue
I recently installed a 4 link and 3 link with pan hard. The issue is when i turn left the suspension cranks down on that side. When turned right it lifts up. Im just wondering if theres a remedy for my issue. Ive adjusted my end points and that seemed to help a little bit. Some other thoughts are upgrading shocks to maybe make it more stiff... Anything helps Beanz Sent from my LM-G820 using Tapatalk |
10-19-2019, 09:24 AM | #2 |
Pebble Pounder Join Date: Sep 2018 Location: Canada
| Re: Tf2 3 link w pan hard steering issue
I don't personally have the 3link but I think shocks with springs on them like a rc4wd king shock or something would help out that lean. Basically with the Leafs installed they are the springs in the suspension and the stock shock is just a travel limiter to prevent rubbing on the body. Might not have alot of clearance for some of the spring type shocks so you will have to do some measuring.
10-19-2019, 09:28 AM | #3 | |
| Re: Tf2 3 link w pan hard steering issue Quote:
Sent from my LM-G820 using Tapatalk | |
Tf2 3 link w pan hard steering issue - Similar Threads | ||||
Pan hard steering link problem | Troublekitty | Axial Wraith | 15 | 11-20-2014 08:03 PM |
4 link Pan Hard? | Case182 | Axial SCX-10 | 12 | 02-27-2014 12:25 AM |
Pan hard/ 3 link set up | foratm | Axial SCX-10 | 13 | 09-15-2012 12:53 PM |
third link and pan hard bar? | demonoid369 | General Crawlers | 4 | 10-26-2010 09:38 PM |
