03-16-2021, 10:39 PM | #1 |
Quarry Creeper Join Date: May 2017 Location: Bellevue
| Stumped! Suggestions?
All you smarter than me (almost everyone please solve this damn issue please! If I compress both front suspension, it rebounds. Compress only left side, it rebounds. Just about every time compressing only the right side and it binds or something. Only physically pulling up brings the right side back up. Oh and oddly (hoping this is a clue into the issue) while right is stuck compressed if I roll the rig back it instantly un-binds and pops up. Not forward, only rolling backwards makes it recover. Removed shocks and work great in hand. Swapped shocks around, and issue remained on the right side. Coil overs are not catching on frame rails/shock hoops. I just don’t get it. Sent from my iPhone using Tapatalk |
03-17-2021, 01:58 AM | #2 |
Newbie Join Date: May 2018 Location: GB
| Re: Stumped! Suggestions?
Maybe the shackle on the leaf spring is going over to far and locking the suspension in place? Sent from my Pixel 4a using Tapatalk |
03-17-2021, 03:42 AM | #3 |
Quarry Creeper Join Date: Jun 2018 Location: Blaine
As far as I can see from the pictures it looks like a yota axle with a 4 link kit and pitbull kronix shocks. I may be wrong but i can't see any leaf springs. Have you checked to if you steering link, panhard or top link are catching are catching anything? Or if your drive shaft is binding at all? With the right side "stuck" do you still have full steering and tire rotation? Sent from my LM-V600 using Tapatalk Last edited by smc-93; 03-17-2021 at 03:45 AM. |
03-17-2021, 03:52 AM | #4 | |
| Re: Stumped! Suggestions? Quote:
Sent from my Pixel 4a using Tapatalk | |
03-17-2021, 04:44 AM | #5 |
Pebble Pounder Join Date: Jan 2017 Location: Brookfield
Check if the balls in the links move freely. Make sure the chassis is not tweaked. Sent from my SM-N950U using Tapatalk |
03-17-2021, 07:53 PM | #6 |
Yep, 3 Link front, (leaf rear) Kronik shocks, Yota II axles. Thought the same, made sure links and pivot balls were free while right side still bound. All move freely. Had a thought today as I pondered on this while I should have been working. So I don’t understand all the proper geometry in regards to links. But if I’m correct, I believe the Panhard and steering link should be the same length eye to eye. When the 87’ Toyota body was released I converted my TF2 to the LWB chassis, added the Pit Bull shocks, etc. As it sat, one shock was very noticeably closer to the frame rail than the other. I corrected this by swapping the Panhard rod ends with slightly shorter ones. Could it be that I created the problem I’m now having by messing with it’s geometry? Sent from my iPhone using Tapatalk |
03-17-2021, 08:05 PM | #7 |
I think you're right on that assumption. I'm pretty sure the panhard and steering link are supposed to be (at least close) to the same length and as parallel to each other as possible. I'm an amateur when it comes to suspension geometry as well, only finished kits so far, but i imagine if the lengths or alignment to each other are too far off, it could cause binding. Maybe they're intersecting each other rather than staying parallel? As far as unbinding when rolled in reverse but not forward, maybe the torque on the axle when rolled backwards is twisting the axle and undoing the bind, opposed to forward "reinforcing" it? Sent from my LM-V600 using Tapatalk Last edited by smc-93; 03-17-2021 at 09:27 PM. |
03-17-2021, 08:06 PM | #8 |
Yep, I think you’re spot on regarding it un-binding when rolled back. Sent from my iPhone using Tapatalk |
03-18-2021, 06:56 AM | #9 |
Hard to tell from the pics, just throwing out a guess... Sounds like the shock is catching the chassis or binding in the upper mount. When the suspension compresses, the axle moves laterally slightly and the shock might not like it. Add a washer or small spacer to the panhard to move the axle over slightly, or use a small spacer in the upper shock mount so it doesn't hang up. With a panhard, the axles in only really perfectly centered at the midpoint of the extension (or wherever you tune it to be, should be centered at static ride height) At full extension looking at the chassis from the front, the shocks should have a slight lean in 1 direction, and at full compression they should lean slightly the opposite way. Just the natural course of things as the panhard swings through its arc. |
Stumped! Suggestions? - Similar Threads | ||||
stumped | zombieghost | RC4WD Trail Finder 2 | 3 | 09-06-2013 12:48 AM |
I am stumped | smokediver | Axial SCX-10 | 2 | 03-10-2013 09:09 PM |
i'm stumped | scx10mudder | Axial SCX-10 | 8 | 01-22-2011 10:41 AM |
Got me stumped.... | Eritex Inc. | Electronics | 13 | 06-08-2009 05:13 PM |
ok im stumped! | STANG KILLA SS | Chit Chat | 13 | 06-21-2006 09:21 PM |
