White Rovers, use the stock foam? I am getting some HB Rovers for my rs10. Just wondering if I should get different foams for them or is the memory foam ready to rock? Thanks |
the stock foams arent the best get some memory foam they work way better |
Do some research on the site. The search function will yield all kinds of results for you. This subject has been hammered to death here in the Tire/wheel section. The stock rovers foams work, Memories work ok, Proline 2-stage work, Novas foams work. Sedona foams work. F-400's work. Just do a search on "ROVER FOAMS" and you'll find everything you could need. Any question on rover foam setups has been answered a hundred times already. Most common foam setup is with the Nova's Double Duece 5.5" foams. The Proline 2-stage foams work just as well IMO as long as the temps are warmer. |
Go with Crawler Innovations double deuce 5.5 foams. These seem to be the best for Rovers. Here is a link... http://crawlerinnovations.com/index....=products&id=2 |
The stock foams aren't bad...I liked them better than the proline memory foam I had previously. I suggest running them with stock foam, then if you don't like it stock, put something else in there. |
Thanks for the help |
I'm a big fan of the Novas 5.5 double duce. I have found that they work great in both the Rovers and the Panther Leopards. For me it's the sidewall folding under on a down hill turn on a grippy rock that really shows the difference. My $.02 |
i run stock foams in rovers. although there is dead space twixed the tire and foam. so far no issues. was looking into the nova 5.5's but thats more than i paid for the tires. If I am going to spend that kind of money i would rather get a better servo and a radio. @jcboof......thanks for posting those links. I never have good luck using seach. |
