Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Redcat Crawlers
Thread: cvd's?... no problem
Old 12-03-2014, 09:31 AM   #21
Default Re: cvd's?... no problem
anyone have something figured out. that stands up to the stock motors.
was looking into traxxas slash universals. will they drop in besides cutting to length. and drilling a pin hole?
JCon is offline   Reply With Quote
Old 12-31-2014, 12:03 PM   #22
They should work with a few mods because I'm using the stock slash/stampede plastic universals from traxxas. I had to dremel the inboard end of the universal shaft to make the setscrew hole align with the hole on the rs10 locker and also had to dremel the inside of the axle tubes because the plastic universals are so big around. I don't think I really increased the steering angle with these but I think it would using steel units . I just tried the cheap plastic ones first to see if they would hold up to my 540 conversion and so far, they are taking the abuse even when i hit the throttle with a front wheel in a bind.
chopfather is offline   Reply With Quote
cvd's?... no problem - Similar Threads
Problem with Tekin RS system in my LCC, will a BEC fix my problem? rcboy514 Electronics 3 01-12-2012 05:55 PM
Tekin Problem or Radio Problem? Harvo Electronics 8 07-30-2010 06:02 AM
Little bit of a problem, Possibly big problem... C_Money Electronics 11 03-08-2010 05:49 PM
Charger problem or power problem? Rockfrog Electronics 4 10-09-2009 01:10 PM
* Problem * Clicking Problem on my 1/18th clodman General Crawlers 6 04-08-2006 08:40 AM
