09-28-2013, 01:52 AM | #41 |
Rock Stacker Join Date: Dec 2012 Location: Slovakia
| Re: New RS10 XT Owner |
09-28-2013, 01:58 PM | #42 |
Pebble Pounder Join Date: Sep 2013 Location: Pierce county
Hey iQlogic the motors are indeed 70t thats what it says right on the front of my rockslide box
09-28-2013, 06:29 PM | #44 |
Lmfao iQlogic, i stand corrected then...;)
09-29-2013, 02:16 AM | #46 |
09-29-2013, 12:23 PM | #47 |
Rock Crawler Join Date: Feb 2011 Location: Courtenay
I wonder what redcat has to say about their not-really-70t motors? They were pretty torquey for a 370, and I've made use of them on boats and such. But on the Cat, they are only up to par on 3s lipo. Most guys need a little more grunt and replace em. As wheel speed goes, rc4wd 45t 540's are virtually identical, so I guess 55t sounds about right. I don't think I could have stayed 370 sized anything. 540 just has so much bloody torque, at any turn. Trade off is though; I can't let the kid play with it. Enough power to shred itself to pieces in the wrong hands. |
09-30-2013, 11:02 AM | #48 |
Newbie Join Date: Sep 2013 Location: Birmingham
Ok, so i got my RS10xt very fun crawler. Both stock servos died and my new servos had not arrived yet so i put in 2 hitec 645MG's work fine. Now I would like more power in this truck so I just talked with Thomas at ZNO and ordered the 540 Preassembled Kit w/ Gear cases, 2 Spur gear pin plates, Hardened steel pins and the outcry dual motor ESC. Already ordered the steel gears from amazon... It will more than likely be about 2 weeks before the preassembled kits will get to my house as they are waiting on redcat to send more gear cases. So anyone have motor suggestions (shortened 540 cans?) and link suggestions? It appears from what I have read here there are no real bolt on options for links, so I am guessing i need to decide on the motors and then do my best to bend some links that will fit and not bind?
09-30-2013, 11:41 AM | #49 | |
| Re: New RS10 XT Owner Quote:
09-30-2013, 09:39 PM | #50 |
Hope this helps with the big-ass-motor swap! http://www.rccrawler.com/forum/redca...mented%3B.html |
10-01-2013, 07:43 AM | #51 | |
It also appears if the motor length is going to be a problem I will need links bent outward, which looks like that will cause steering issues. Jackalope have you changed your lower links since your right up on the 540 conversion? I can see in your final pictures the links are bent outward, how much steering did you loose, or did the wheels turn fine with no rubbing? Last edited by Eric76; 10-01-2013 at 08:07 AM. | |
10-01-2013, 09:53 AM | #52 |
Those pinions look good. Links bent out worked well for me, and didn't bother steering too much. Minor rubbing but didn't hinder performance. The "S" bend seems to be the most popular though. My rod-ends threads are all worn out and I'm due for a rebuild. the links are floppy, don't stay in position. I'm working on a gearcase rebuild/design. soon I'll be running Straight lower links all around, or a slight "S" bend on the rear........ I hope. Tip- If you bend your links, you might want to move the shocks to the axle. otherwise they get real floppy. |
10-01-2013, 10:26 AM | #53 | |
Also with so much more torque what all have you broken? Driveshafts (dogbones), wheel shafts (Stub axles/output yokes) , outdrive cups (gear output yokes), etc... Last edited by Eric76; 10-01-2013 at 11:00 AM. | |
10-01-2013, 06:05 PM | #54 |
| Re: New RS10 XT Owner Just steering knuckles and diff pins(snapped an allen key). Debeaded a tire or two. broke rod ends on links/shocks when twisted and in a bind. Spun wheel hexes. Thats about it really. My dogbones are even original still.
10-02-2013, 07:24 AM | #55 | |
Do you use the optional diff:RCT-T007 And very important question if someone can please help me out with this, the new Lansu rx on the RS10xt when I install the outcry ESC (with BEC) can i plug the BEC into the fourth slot on the Lansu rx? and will the Lansu RX handle 6v/5A? Thanks, Eric Last edited by Eric76; 10-02-2013 at 11:06 AM. | |
10-04-2013, 01:18 AM | #56 |
Rock Crawler Join Date: Aug 2011 Location: south shore Ma
The best thing i found for figuring out links is to buy some threaded rod from home depot. Get some revo ends and bring one with you to match up the thread. I wanna say its 6-32 but check first. Then you can just cut and bend that easily and make some mock up links. After you are happy with the way they came out make them out of stainless or titanium. I have also seen people just slide some brake line right over the rod after and keep it that way. Sent from my iPhone using Tapatalk - now Free |
10-04-2013, 01:35 PM | #57 | |
Quarry Creeper Join Date: Oct 2012 Location: Cashmere (central WA)
10-04-2013, 02:55 PM | #58 |
I have axial aluminum steering knuckles on mine and it was a direct fit. Its a nice upgrade too. As for the lansu rx im not sure about that because mine was the old 27mhz model so i swapped it out for a flysky gt3b. Sent from my iPhone using Tapatalk - now Free |
10-04-2013, 03:30 PM | #59 |
I have another week or so before the build weekend as I am waiting on the 540 kit. My goal was to stay under 300$ and have a capable crawler, which I am barely under 300$ right now, so I really hope I don't need to purchase a new RX/TX. At some point I probably will but I am hoping I can use the Lansu for a while and still have fun with this rig. Thank you Pat for taking a look at yours really appreciate it. Thank you for the link suggestion JC, I am unreasonably hoping I can keep the links straight somehow but in looking at pics from others that have done the 540 conversion I think I will have to bend them. First things first I need to get the 540's in there and see how much room I have to work with. |
10-04-2013, 08:51 PM | #60 |
OK, home and pics loaded Battery - connected to -1: ESC (Outcry speed control) 2: Lipo alarm (set for 3 cell lipo) & 3:Outcry BEC box From Outcry BEC box - 1:reciever & 2:ESC fan added: wiring to receiver goes as: 1: front servo steering 2: speed control on ESC 3: rear servo steering 4: fan on ESC & wires from BEC (spliced together before plug) Last edited by Pat M; 10-16-2013 at 09:45 AM. |
New RS10 XT Owner - Similar Threads | ||||
New RS10 XT owner. HELLO | Wi_Crawler | Redcat Crawlers | 16 | 11-11-2014 08:02 AM |
First time RS10 owner, need advice | scottgir | Redcat Crawlers | 1 | 12-18-2011 05:36 AM |
New RS10 Owner - XL5 swap ? | MarkM | Redcat Crawlers | 2 | 12-25-2010 07:26 PM |
New rs10 owner | camobob | Redcat Crawlers | 4 | 02-19-2010 08:07 AM |
A canadian RS10 owner | Cam_L | Redcat Crawlers | 6 | 01-25-2010 10:08 PM |
