Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Redcat Crawlers
Thread: Bought my first crawler. Build thread?
Old 06-12-2014, 09:33 AM   #41
mtm
Thanks for the tips guys,
- Matt
mtm is offline   Reply With Quote
Old 06-12-2014, 09:42 AM   #42
Default Re: Bought my first crawler. Build thread?
Simple Green makes tires sticky. Try letting them soak in it for a bit then rinse them off...you should be able to stick them to each other right after that lol. But it picks up a lot of crud fast and loses that tack right away.
MountainStorm is offline   Reply With Quote
Old 07-28-2014, 05:47 PM   #43
Another amazing build!
I have a question. How long were links before bending?
Many thanks
IQLogic is offline   Reply With Quote
Old 08-06-2014, 10:39 AM   #44
mtm
Thanks, sorry i can't find my measurements on the links :\
Old 08-17-2014, 05:29 PM   #45
Awesome build! I just started getting into modding the chassis/links/wheels when I stripped out the spur cap. Really wish the metal gear set had a metal cover!
infodragon is offline   Reply With Quote
Old 08-27-2014, 01:06 PM   #46
mtm
Little update. I haven't done a lot to my truck as I've been busy catching up on house work and playing with the kiddos. I did manage to squeeze in enough time to strip the old copper orange anodizing from the frame and beadlocks. I also painted the body white. I know it won't look good after the next run but that's part of the reason I did it. Scratch a little of the while to expose the black giving it character. Next thing I want to do is the BTA mod. All in due time.
Old 08-27-2014, 03:59 PM   #47
Nice but chassis looks too small for 2.2 crawler :P
Old 02-25-2015, 03:31 PM   #48
mtm
Been a while on this build guys, been working on my 1/24 Crawler. Anyway, I decided to get a proline '73 Bronco body. Got it all trimmed out except for a little finish sanding but I'm really liking it. The dimensions fit great. Now I just need to figure out how to mount it and paint.
Old 02-25-2015, 09:39 PM   #49
instead of finnish sanding try swedish sanding a lot nicer
by the way that chassis in white is a lot better so tired of that oraange good job.
there again, you are a ford man
cabron is offline   Reply With Quote
Old 02-26-2015, 04:26 AM   #50
mtm
Yes sir, what's Swedish sanding?
Old 02-26-2015, 07:02 AM   #51
a bit smoother than finish sanding
Old 03-29-2015, 10:07 AM   #52
mtm, did have any trouble getting the screws through the replacment metal gear on the axle when you replaced the drive gears?
papa tom is offline   Reply With Quote
Old 03-29-2015, 10:24 AM   #53
mtm
I haven't changed the gears yet, sorry.
Old 04-21-2015, 12:34 PM   #54
mtm
Little update, I'm afraid my rs10xt stock motors are going to be hating life soon lol.
Old 04-21-2015, 01:15 PM   #55
With those tires and flex you'll definitely have to do some trimming to that bronco body.
tony91723 is offline   Reply With Quote
Old 04-21-2015, 04:37 PM   #56
What's the specs on the tires? Sizes?
Damion10 is offline   Reply With Quote
Old 04-21-2015, 04:41 PM   #57
consider some wheelbase wideners. 13mm will really help you here.
with the taller tires you will be limiting your turning radius when the tires hit the
suspension links and/or motors and/or shocks
besides that looks good
Old 06-25-2015, 10:31 PM   #58
How's the build coming? I just bought 3 RS10's. One for myself and 2 for my sons.
Really looking forward to seeing how yours turns out
Otis Fudpucker is offline   Reply With Quote
Old 06-26-2015, 06:08 AM   #59
mtm
Sorry guys I've been super busy at work. Haven't had any time to work on the rig. I did decide to sell the bronco body to my buddy and do some extensive trimming to the stock redcat hummer. I also painted it silver. I am going to trim the body posts a little shorter, work on getting the behind the axle mod completed and a few other odds n ends buttoned up this coming week as I am on vacation.
Old 06-26-2015, 08:46 PM   #60
It's a little late to tell you but spray carb cleaner and a rag will take the factory paint right off of the stock shell. Then you can paint it on the underside. Looks good though!
Bought my first crawler. Build thread? - Similar Threads
New Crawler king build thread!!!! kreeperxj HPI Wheely King 0 04-28-2012 09:19 AM
Black Metal Crawler! (build thread) KROGOTH Axial AX-10 Scorpion 35 06-22-2011 11:04 PM
my super crawler build thread Mr.RC4x4 Newbie General 20 10-14-2010 07:38 PM
I hobby 2009 crawler course build thread jetboat General Crawlers 184 11-18-2009 07:09 PM
