Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Redcat Crawlers
Thread: Short obstacle course footage.
Old 05-31-2014, 10:14 AM   #1
Default Short obstacle course footage.
My Modded RS10 over a small course camera work courtesy of my daughter.
Spec:
Manta type custom chassis
Rover HB whitedot tyres
Rim weighted wheels
Electric tray elimination
Custom front servo battery mount
Rear steer lockout
Batwing elimination.
Internal 3mm shock limiters
Alturn Ultra high torque 17kg Servo
Aluminium Servo horn
Axial 55t 540 motors
Steel gears
Pinions 12t 13t
Spectrum 2 channel TX/RX
https://www.youtube.com/watch?v=eFlzDxB2Slg
bezzy3004 is offline   Reply With Quote
Old 05-31-2014, 11:31 AM   #2
Default Re: Short obstacle course footage.
seems to work very nice. homebuild chassis?
iDC5 is offline   Reply With Quote
Old 05-31-2014, 12:48 PM   #3
Yes i am surprised at how much of a difference the new chassis has made over stock this chassis cost me about $10 to make makes you wonder why the manufacturers dont stick to this proven design. One question i do have though maybe a little nooby, my modded RS10 is not too far away from being able to negotiate verticle climbs, what would an RS10 need to be able to do to be not necesarily a winner but be able to compete in competitions?
Old 05-31-2014, 04:59 PM   #4
No rear steer, decent cog, and dig.
I am not sure what the length requirement is, but you look a little on the long side in the video.
Overkel is offline   Reply With Quote
Old 06-01-2014, 06:34 AM   #5
Just need a dig setup then and i'm good to go. The wheelbase is 13.2" so yes this would need reducing too.
Old 06-01-2014, 12:45 PM   #6
12.5 " LENGTH.
dig for nething vertical is a must
Old 06-03-2014, 10:39 AM   #7
I found dig per se is highly over rated. It's stall that is the culprit and punk dig would not cure that...all or nothing dig has not proven useful to me. The real answer is proportional speed control to each axle then you can modulate on the fly. The only time I go 100% dig on the rear is descending or when I want to pivot by dragging the front around. When I ascend I find that power to the rear is essential.
You would need a different RX TX and a pair of ESCs to set that up. MOA without dual ESCs is not going to do the job if you want to be able to do everything you see comp MOA rigs doing.
Steering angle will be the real road block I think.
I never acheived a real increase in steering angle with the RS10 axles. If you can you will be amazed at what you can do on the rocks. I got to drive a comp AX10 shafty with modded universals, Wraith knuckles, 8 degree c hubs and Zero Ackerman steering arms and I never once thought "I need dig" because the rig could steer and you could do things with the front tires that are hard to explain. This of course requires a monster of a servo.
MountainStorm is offline   Reply With Quote
Short obstacle course footage. - Similar Threads
Cheap Indoor Obstacle XDR Axial Wraith 8 10-13-2011 02:35 PM
Obstacle Course PICS. El Matador General Scale Talk 1 01-30-2011 11:34 PM
new finishline obstacle? flapjack Colorado 39 10-18-2010 02:10 PM
obstacle grading system???? Santa Cruz Jeff General Crawlers 23 03-11-2010 12:43 PM
Backyard obstacle jadama Tamiya CR-01 25 11-15-2008 12:32 PM
