Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Redcat Crawlers
Thread: Everest 10 rear steer question
Old 11-11-2015, 12:56 PM   #1
Default Everest 10 rear steer question
Can someone please post a pic of your rear steer Everest 10, so I can get some ideas on the mod for best results. Thank you all.
Steelers fan 44 is offline   Reply With Quote
Old 11-12-2015, 05:22 AM   #2
Default Re: Everest 10 rear steer question
Just look at your front axle. Yup, that's what the real axle will look like when it's done.
Jeepiac is offline   Reply With Quote
Old 11-12-2015, 07:58 AM   #3
MODERATOR™
EeePee's Avatar
Or put the body on backwards.
EeePee is offline   Reply With Quote
Old 11-28-2015, 04:28 PM   #4
I used rs10 esc and 3channel radio. Almost done with this, well...almost.
P.A.Myers is offline   Reply With Quote
Old 12-06-2015, 09:49 AM   #5
Is there a write-up or how-to on adding rear steer? I understand the components, but I can't figure out how to do control and wiring?
theSLEEPER is offline   Reply With Quote
Old 12-06-2015, 10:23 AM   #6
the easiest and most useful way is to get at least a 3 channel transmitter/receiver setup.
you use one channel for the esc and 2 channels for the steering servos. should be able to set it up
to do both together or either one or even one reversed from the other.
I say at least a 3 channel transmitter but you can never have enough. you might want later to add lights,
winch, or even go to an moa with 2 motors so at least a 4 channel.
or my preference is to use an airplane (stick radio) transmitter. you can get them used in ebay at a good price.
I use a spectrum 7 channel, receivers from hobbyking cost about 10.00 each. the radio has 20 memory locations
for multiple cars. horizon hobby will gladly convert it over to car for free.
the cheap and easy way is to use a "y" harness and parallel the front and back servos but you wont have
the easy switchability between the diffetrent setups
if you don't want a stick radio get a flysky gt3b or gt3c (?) with the hack from overkillrc
Welcome to OverkillRC -
cabron is offline   Reply With Quote
Old 12-07-2015, 07:01 PM   #7
I went with rs10 radio, receiver and esc [e401]. You will also need a servo, servo plate and arm. Also the short steering link and another pair of
front suspension arms [bent for steering clearance]. A few screws and you have 4ws. Everything fits, no surgery or glueing needed.
On front steer it has a huge turning radius. 4ws is big bonus, makes a huge difference. This is one way to do it, not the only way.
Old 12-08-2015, 05:41 PM   #8
So, for a functional setup now, can I just get a servo cable splitter? I'm assuming I need a reverse servo cable splitter?
Old 12-08-2015, 07:18 PM   #9
yes
to get basic 4ws full time where the front points one way and the rear the other
you need a splitter with one end reversed ( or a splitter and a separate servo reverser
if you cannot find one a "y" with included reverser)
Everest 10 rear steer question - Similar Threads
Rear steer servo question JDIRCC Axial Wraith 4 01-21-2015 11:22 PM
Scorpion Rear Steer Kit Question... mystic122468 Axial AX-10 Scorpion 13 11-11-2008 01:51 PM
Rear steer Question? run2jeepn General Crawlers 3 12-16-2005 03:27 PM
Rear Steer Question whuzzz_up_dogg Newbie General 3 12-13-2005 08:48 AM
