04-29-2020, 03:44 PM | #1 |
Newbie Join Date: Apr 2020 Location: Salem
| Gen 8 AXE Brass
Can I use regular gen 8 brass for my AXE? Sent from my iPhone using Tapatalk |
04-29-2020, 08:03 PM | #2 |
Quarry Creeper Join Date: Mar 2018 Location: Indonesia
| Re: Gen 8 AXE Brass
To my understanding the AXE version only differs in the ESC/motor combo. Brass etc will be the same.
04-29-2020, 10:14 PM | #3 |
Quarry Creeper Join Date: Jun 2015 Location: France
| Re: Gen 8 AXE Brass
Portal covers and diff cover should fit, they are not different ... however axles tubes (if they exists in brass, never mind looking) may not, AXE has double-shear axles while Gen8 has single-shear.
04-30-2020, 09:58 AM | #4 |
Rock Stacker Join Date: Jan 2020 Location: US
| Re: Gen 8 AXE Brass
Does it really need brass? I have found it to be very capable just with chanquish wheels, deep woods tires and proline dual stage foams. The drivetrain under that is Axe platform. Sent from my Pixel 3 XL using Tapatalk |
04-30-2020, 10:15 AM | #5 |
Rock Crawler Join Date: Nov 2014 Location: North to Alaska - go north, the rush is on....
| Re: Gen 8 AXE Brass I just swapped out to the Redcat Aluminum Inner and Outer Portal Covers, because I had a mishap that broke a factory plastic one (my fault) and used the C-Hubs that were provided (as a surprise) from mgputer, once you move to the "hard" parts, you lose the double shear on the lower shock mount. I inquired about this with RedCat and they said it was not needed when you move to the aluminum parts. Now, this is all factory parts, not sure what the aftermarket is doing.
04-30-2020, 02:42 PM | #6 |
| Re: Gen 8 AXE Brass
i went the aluminum route to but the added some low hanging fruit to lower the cog some and to get some more bite i mounted these guys on all 4 corners |
05-04-2020, 10:04 AM | #7 | |
| Re: Gen 8 AXE Brass Quote:
Other differences are: 1. HD axle housings 2. Flat bottom skid and redesigned battery tray 3. CNC machined transmission and transfer case gears 4. HD portal gears 5. In phase drive lines 6. Redesigned servo horn to eliminate bump steer | |
Gen 8 AXE Brass - Similar Threads | ||||
Help: Gen 8 axe axl steering link issues | BLACKAXEE | Redcat Crawlers | 9 | 06-30-2020 03:52 PM |
red cat gen 8 axe foams | slgen8 | Redcat Crawlers | 4 | 04-06-2020 11:45 AM |
Gen 8 axe | Sflo | Redcat Crawlers | 2 | 12-29-2019 12:52 AM |
Redcat Gen 8 AXE Edition Details | driftomaniacs | Scale Videos! | 0 | 12-02-2019 07:33 PM |
Hot Racing brass parts for the Gen 8 | svt923 | Redcat Crawlers | 11 | 04-05-2019 06:38 AM |
