11-18-2017, 04:09 PM | #1 |
Quarry Creeper Join Date: Dec 2012 Location: Pioneer, 95666
| XR10 mod for the Gen7!
Edit:after trying to run it, it's too tight between the C-hub and knuckle causing the XR10 axle joint to bind against the C-hub. It does work with the VVD's though with no issues, still improving the steering a lot. What I originally posted: I just used axial high steer knuckles and some cut down XR10 shafts to mod the steering. I'll post up some pictures later tonight. It's easy though, since the axial knuckle fits right over the redcat C-hub. Last edited by makya; 11-19-2017 at 01:09 PM. |
11-19-2017, 03:36 AM | #2 |
RCC Addict Join Date: Apr 2009 Location: LA
| Re: XR10 mod for the Gen7!
So you can use the xr10 universals with the stock Gen7 parts?
11-19-2017, 01:08 PM | #3 |
| Re: XR10 mod for the Gen7! No, unfortunately the universal joint is too long. You can use the cvd's or VVD's with the stock knuckles and hubs, but they limit the steering. That's why I recommend using high steer knuckles, since they don't limit the steering. The axial cvd's or VVD's allow for more steering angle than the stock redcat cvd's also.
11-20-2017, 04:35 AM | #4 |
Thanks for the good feedback! |
11-20-2017, 07:12 AM | #5 |
Moderator Join Date: Aug 2017 Location: Readsboro, VT
On my Gen7 I clearanced the parts enough that I ran out of steering when the CVDs reached their limits, not because of issues with the knuckles hitting the axle tube. It's good to know that other CVDs will give me more angle. When I break one of these, I'll seek out something else, along with new lockers to accept them.
11-20-2017, 03:13 PM | #6 |
Quarry Creeper Join Date: Aug 2017 Location: KY
My guess is if you used the XR10/wraith chubs & knuckles, it'd work fine. The plastic bits from Axial are cheap enough to try and see.
11-20-2017, 09:18 PM | #7 | |
| Re: XR10 mod for the Gen7! Quote:
11-20-2017, 09:22 PM | #8 |
| Re: XR10 mod for the Gen7! I agree. I just have to pick some up. New holes have to be drilled to secure the C-hub though, since the redcat mounting holes are further inboard than the axial
11-21-2017, 07:32 AM | #9 |
| Re: XR10 mod for the Gen7! Unlike a lot of guys whose videos seem to show the tires turning enough to contact the springs, I found that at full lock the CVAs were getting "notchy", which means it was putting pressure on those pins. I backed off accordingly on the steering.
XR10 mod for the Gen7! - Similar Threads | ||||
Xr10 steering mod | Unfadingpyro | Axial SCX-10 | 14 | 06-13-2015 12:51 AM |
XR10 2 Screw Mod | jaloos | Axial XR10 | 8 | 06-25-2014 10:01 AM |
XR10 Bushing mod? | norco kid | Axial XR10 | 15 | 03-26-2012 09:11 AM |
VP knuckle mod on xr10 - Wraith or XR10?? | 001Hulk | Axial XR10 | 9 | 01-03-2012 01:15 PM |
