Go Back   RCCrawler Forums > Vendors > RPP Hobby
Thread: IN STOCK NOW the NEW SSD SCX10 II Portal Knuckles & Rear Axle!
Old 12-11-2018, 11:59 AM   #1
RPP Hobby's Avatar
Default IN STOCK NOW the NEW SSD SCX10 II Portal Knuckles & Rear Axle!
https://tinyurl.com/RPPSSDPortal1210
RPP Hobby is offline   Reply With Quote
Old 01-20-2019, 09:38 AM   #2
Default Re: IN STOCK NOW the NEW SSD SCX10 II Portal Knuckles & Rear Axle!
I have bought the SSD portal knuckles and rear portal axle for my SCX10 II. I have taken it out for trailing 3 times, the 1st time, everything was fine, the second time, one plastic axle tube was broken and it caused the shock shaft and lower link to break too. The 3rd time, both two plastic axle tubes were broken and I was exhausted in this problem.
I am strongly request SSD to provide metal axle tube for the rear portal axle. I really don’t want to break the plastic axle per each run. I took my truck for hiking, and the axle was broken in the mid way, I needed to take the truck walking for more than one hour to the destination, it is not fun .....
rchyam is offline   Reply With Quote
Old 01-21-2019, 09:18 AM   #3
RPP Hobby's Avatar
Thank you for the feedback, SSD is currently working on this product and until cleared by SSD the item is not available. Stay tuned, we will provide info as it becomes available to us. Nate - RPP Hobby
Old 02-04-2019, 03:31 AM   #4
mine got from RCmart (sry..)
but front axle CVD broke after only 3min of running.
this item really has issues.
I send a contact message from their site. hope they solve it.
Peros is offline   Reply With Quote
IN STOCK NOW the NEW SSD SCX10 II Portal Knuckles & Rear Axle! - Similar Threads
SSD portal kit for SCX10 2 axle Traulus Axial SCX10 II 66 02-10-2020 02:14 AM
In Stock Now - New SSD Portal Delete Kits For TRX-4! RPP Hobby RPP Hobby 0 02-08-2018 10:14 AM
New SSD SCX10 II Axle Gear Set & Knuckle Bushing - In Stock! RPP Hobby RPP Hobby 3 06-05-2017 05:21 PM
Stock yeti RTR wheels & SSD axle question Jeep757 Axial Yeti 12 11-26-2016 09:02 AM
Shapeways 3d printed portal axles, knuckles, t-case, axle housing for scx10 Shinjari Axial SCX-10 29 09-28-2016 06:48 PM
You may edit your posts
