Go Back   RCCrawler Forums > RCCrawler General Tech > General Crawlers
Loading
Thread: building my own crawler
Old 11-02-2008, 02:30 PM   #1
Default building my own crawler
I'm busy building my own crawler so I thought Id share
front and rear hubs , drive shafts from a losi 8 T
motors and gearboxes: Tamiya , geared to 344:1
controller: Hi Tek Ranger II N
shocks: T max 2.5
still to go:Associated ball studs and caps , eBay esc ....
http://s267.photobucket.com/albums/i...u357/crawler2/
buju is offline   Reply With Quote
Old 11-02-2008, 03:12 PM   #2
sorry to say but that gearbox will never work. the motor is to small the gears will snap. but it is a very nice attempt.
Georgerm is offline   Reply With Quote
Old 11-02-2008, 03:20 PM   #3
looks like a lot of hard work there.
keep us posted
crunky is offline   Reply With Quote
Old 11-02-2008, 03:22 PM   #4
did u build that axle?
nitrosport963 is offline   Reply With Quote
Old 11-03-2008, 01:25 AM   #5
Default built it myself
yes , built it myself , pics are of the front and rear out of a t bar aluminum piece , hubs and shafts (shortened) are from a losi 8 T , kinda hard to manufacture hubs yourself. The front axle weighs in at about 300 grams , the rear at under 200 grams , so total weight for front and rear is already 500 grams , half a kilogram , in my opinion , all the better for steep inclines and to keep the wheels firmly pressed to the ground ....
Old 11-03-2008, 04:24 AM   #6
if those gearboxes end up not working i would try bolting on some t-maxx diffs or something and run an axial trans.
yoda316 is offline   Reply With Quote
Old 11-06-2008, 06:18 AM   #7
Default bench test of the front axle , watch the vid
http://www.youtube.com/watch?v=swR_1DX-buA
Old 11-08-2008, 12:28 PM   #8
Default been busy
this setup can articulate to about 40 deg., unfortunately the shocks / springs can only compress up to this point ....
Old 11-08-2008, 08:58 PM   #9
interesting build, im curious to see how it holds up for you
samb. is offline   Reply With Quote
Old 11-09-2008, 10:15 AM   #10
Instead of the shock mounts the way youve got them now,why not make side plates ,as in one peice and a link in between.
Nice job though.
vipxj is offline   Reply With Quote
Old 11-09-2008, 12:54 PM   #11
Default started with the rear suspension
Old 11-10-2008, 12:53 PM   #12
Default getting there
some articulation ...
front clearance 7cm
center clearance , almost 12 cm
Old 11-10-2008, 02:30 PM   #13
Props for being unique and thinking outside the box!
sid lives is offline   Reply With Quote
Old 11-11-2008, 01:04 AM   #14
I'm going to shorten the arms a bit and move the shocks to a slightly more upright position , Im also going to put a arm in the center of the axle because the only thing keeping the axle from rotating is the shocks.
trail and error but this is my first attempt ,
Ive already got plans to build a 6 wheel drive crawler ...hmmm
Old 11-11-2008, 02:09 AM   #15
Nice! Good to see some guys still building there own rigs.
Rockcrawler is offline   Reply With Quote
Old 11-11-2008, 04:46 PM   #16
Wow! holy ground clearnce.
clayton78 is offline   Reply With Quote
Old 11-20-2008, 09:06 AM   #17
In this ARTR crawler world, its great to see someone building a rig from what they have not what there budget will allow them to buy... hats off to you for your valiant effort....
HauntFreaks.com is offline   Reply With Quote
Old 11-20-2008, 10:32 AM   #18
On the lookout for Rocks
constantmotion's Avatar
This build just makes me laugh. I love it. It is good to see ppl stepping outside of the box "with a handful of scraps" and building things. I see some issues but can't wait to see a vid of it completed. I just don't thing the gears are going to hold up. I would like to see that I'm wrong, though.
constantmotion is offline   Reply With Quote
Old 11-20-2008, 10:36 AM   #19
looks interesting , I would like to see this thing woork for you, you got to post a vid when you have it all running on the rocks. What body are you going to use?
ctrwannabe is offline   Reply With Quote
Old 11-20-2008, 01:26 PM   #20
hey guys , reading your posts puts a smile on my face ....
well it did run , quite nicely actually , over rocks , steep inclines , building bricks ..... until .....the first gearbox stripped and a then the 2nd one stripped ....lol , so I replaced the stipped gears with a higher ratio and i was back in action , for 2 hours I had great fun .....until ......it stopped dead and wouldn't move , well 2 x 130 mabuchi motors burnt out .....lol
pity there ware no vids ....
one thing that did work better than expected was the articulation , so I think ive got that nailed for now.
so Ive stretched my budget and ordered up a set of 2 x traxxas Erevo diffs , Im thinking of locking the rear and making the front " limited slip" , and 4 x Erevo drive shafts , also , (Im on a budget) , I have bought 2 x cheap electric screw drivers that have 3.6v 380 motors and planetary gearboxes spinning at 250 rpm max , this will all be installed in due course.
You may not edit your posts
