07-08-2010, 10:03 AM | #1 |
RCC Addict Join Date: Jul 2009 Location: Ontherocks
| Ring and pinion problems
I posted on another thread about how my pinion was not meshing or holding mesh with the Ring gear in the diffs and that would cause some terrible clicking/grinding noise and that it was the lack of the outer bearing on the outputs was the problem. Well yesterday i got some Traxxas sealed ones that were the same size...nope still does it. Ive taken the axels apart numerous times and it all looks good. If i take the driveshaft off and hold the output and turn a wheel, i am able to make the R and P skip. its just 10 times worse when its under power. both the front and rear diffs do it. Could it be that either the ring or pinions are defective and i would need to contact venom or is it something im doing(or didnt do) |
Sponsored Links | |
07-08-2010, 01:13 PM | #2 |
RCC Addict Join Date: Mar 2010 Location: Colorado Springs, Co
Mine does that too drone time to time. I think that if you shim between the bearing and the pinion gear it will give you a better mesh. I've not gotten around to trying it yet because I don't feel taking it apart just yet because it's not real bad yet. Probly take the pinion to the hardware store and sindva small thin washer to use as a shim would work.
07-08-2010, 02:46 PM | #3 |
oddly enough i just might have solved my own problem. I was pulling the diff apart to investigate Abavuso's spacer fix, when i pulled the pinion out i looked at it and wiped off all of the grease. "It shouldn't look like that". I dug through more grease in the casing and found the broken splines from the pinion. the pinion was completely wasted. I know that it was not my fault and it was a manufacturing thing because ONLY the small splines are broken I opened up the front diff but not the rear however im pretty sure its the same as the front. So a call will be made to Venom ... hopefully they can get my replacements here before my trip in a little more than two weeks |
07-08-2010, 03:21 PM | #4 |
I wanna be Dave Join Date: Jan 2006 Location: ...the burning end of the rope.
| see the axle was pregnant and having babies,,,,sorry. gottorque,,,,I know you know now but for the sake of argument and questions that will be asked later on when we have to link this thread 10-15 times for people......when you take your axles apart,,,clean the internals and regrease them after you inspect everything. |
07-08-2010, 03:38 PM | #5 |
whether i cleaned them in the past or not is not the point. Ive had the truck for 2 weeks. its ran for all of five minuets, and its sat the rest of the time ...not to mention it has two destroyed pinions. Venom has an email waiting for them |
07-08-2010, 04:20 PM | #6 |
what I meant was,,,,you said you had them apart and didnt see the problem right? im not trying to ruffle your feathers bro...just saying,,its good practice to clean when open and regrease before closing
07-08-2010, 10:36 PM | #7 |
| Sorry man. I didnt mean to sound short. Im just slightly frusterated that it has bearly run at all and the entire time i have had the creeper, ive had thoughts about switching to axial axles as a last resort. but if i did that it would rid it the name creeper and the build thread would have to be moved to the ax10 thread.. I will just be patient
07-09-2010, 04:43 PM | #8 | |
| Quote:
07-09-2010, 05:18 PM | #9 | |
Rock Crawler Join Date: Apr 2008 Location: Greentown
| Quote:
The washer mod... | |
07-09-2010, 07:35 PM | #10 | |
| Quote:
Uh actually they are talking about shimming the pinion not locking the locker | |
07-10-2010, 12:21 AM | #11 |
I have flm spools madmax My build thread is here gottorque's Underground Creeper Venom emailed me back and he was un shure about what caused it. He suggested it might be some left over flashing from the housing molding process but i didnt see anything. ill look again Last edited by gottorque; 07-10-2010 at 12:24 AM. |
07-10-2010, 10:49 PM | #12 | |
| Quote:
07-11-2010, 05:11 AM | #13 |
Pebble Pounder Join Date: Mar 2010 Location: Flat Orlando
Something is allowing the ring and pinion to move under torque. Did you shim them? Its not an issue with the ring or pinion or you would have snapped several teeth in a row. There is a bind when they rotate, when the gears get to the bind spot, they push away from each other. When they push away, the only weak point is the plastic housing. Check the fit on your bearings in the housing. If they are ovaled out, you found the problem. It is very rare that any manufacturer messes up the heat treat process.
07-11-2010, 08:50 PM | #14 | ||
| Quote:
Quote:
08-02-2010, 07:50 AM | #15 |
Newbie Join Date: Jul 2010 Location: IN MY OWN WORLD..(GULF COAST)FT WALTON
| Same gear mesh issue
Mine did the same front first then rear, venom said they never heard of this issue,but they sent me 2 sets after first issue ,now i need a permanent fix..i too shimmed the front.
08-02-2010, 01:11 PM | #16 |
| Venom sent me 2 new pinions a couple of weeks ago looking at the new ones vs. the ones that were from the kit, the kit ones were just plain wrong ones as the new ones looked completely different. but since i put the new ones in ive had no problems what so ever. thanks Venom |
08-02-2010, 05:11 PM | #17 |
Good to hear you got it sloved and I think you should post up in the TIP AND TRICKS thread about this,,so others will know what to look for if they have the same or similar porblem/s.
08-03-2010, 09:54 PM | #18 |
I'll wait until it is a proven issue,got an e-mail after the 2nd one reported to venom ...it said .i need to get the 27 turn out of it so i am waiting on the 55 in the mail,also some rovers
08-03-2010, 10:01 PM | #19 | |
| Quote:
08-03-2010, 10:22 PM | #20 |
Rock Crawler Join Date: Feb 2010 Location: eugene
