Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Traxxas Crawlers
Loading
Thread: Maxx Crawlers Gallery
Old 03-09-2005, 03:49 AM   #1
Colt Python/SR9c
TwistedCreations's Avatar
Arrow Maxx Crawlers Gallery
This has been requested from other Members, so it's time to post up your rides and keep them all in one spot so others can view them and help give ideas.DO NOT post pictures of projects torn in pieces,they need to be driving and in one piece.Have at least one picture with the body on and not a bunch of chassis shots( unless it's a tuber).Pics that DO NOT work( due to the host), will also be deleted.If you see something in the pics and want more info, please PM that person and ask. This will keep all the BSing to a minimum.
If you guys can't re-size, you can send them to TwistedCreations@cinci.rr.com and i will try to help ya out
answer the following ( copy and paste if ya want)
Truck Base :
ESC:
Motor(s):
Servo(s):
Trans:
Axles:
Tires:
WB:
Overall Width:
Diff clearance:
Center Chassis clearance:
Overall height:
Overall weight:
TwistedCreations is offline   Reply With Quote
Old 03-09-2005, 07:36 PM   #2
Truck Base: E-MAXX
ESC: EVX with mod
Motor: Mag Mayhem
Servo(s): Hitec 5625(f) 5625(r)
Tranny: E-MAXX
Axles: Emaxx locked out (diffs locked)
Tires: Jumbo kongs
Wheelbase: 16
Overall Width: 18
Diff clearance: 4.5
Center Chassis Clearance: 4.5
Top of Chassis Height: 9
Top of Body height: 13
onewyr is offline   Reply With Quote
Old 03-12-2005, 04:51 PM   #3
My old Maxx
Truck Base : E Maxx
ESC: Futuba 230
Motor(s): Multiplex 600
Servo(s): Hobbico CS80
Trans: Narrowed single speed e maxx
Axles: Custom aluminum sheet axles with maxx internals
Tires: cut LST's
WB: 16.5
Overall Width: 15.5
Diff clearance: 4.25
Center Chassis clearance: 5
Overall height: 10
Overall weight: ~8
CustomCrawler is offline   Reply With Quote
Old 03-28-2005, 10:12 AM   #4
Truck Base : E-Maxx
ESC: Novak Rooster
Motor(s): Trinity Spec. (soon to be lathe motor)
Servo(s): Bluebird 630mg(front)/ Futaba S9201(rear)
Trans: E-Maxx locked in 1st
Axles: Maxx hybrid(used Twisted's idea!!)
Tires: Imex J Hawgs on Maxximizer beadlocks
WB: 15"
Overall Width: 14.5
Diff clearance: 2.5
Center Chassis clearance: 4.5
Overall height: 10.5
Overall weight:about 8lbs
silvr_tung_devl is offline   Reply With Quote
Old 03-29-2005, 06:25 AM   #5
Colt Python/SR9c
Truck Base : Maxx
ESC: Super Rooster
Motor(s): Johnson 27t w/ GD600
Servo(s): Cs-70's F&R
Trans: Maxx locked into 1st
Axles: Hybrid Maxx axles
Tires: LST's on narrowed stock maxx rims
WB: 17"
Overall Width: 16"
Diff clearance: 4.5"
Center Chassis clearance: 5.5"
Overall height: 12"
Overall weight: 10lbs.
Old 04-13-2005, 09:06 PM   #6
Colt Python/SR9c
Posted for Extremeoffroad
Truck Base : Maxx and gecko
ESC: EVX with both mods
Motor(s): mag mayhem
Servo(s): hitec HS-5735MG 1/4 scale
Trans: e maxx
Axles: t maxx locked out
Tires: jumbo swamp dawgs
WB: 18in.
Overall Width: 17
Diff clearance: 4
Overall height: 12in
Old 04-20-2005, 04:38 AM   #7
BDR
Truck Base :E-MAXX
ESC:EVX one battery one motor
Motor(s):Mag mayem with reduction box
Servo(s):645
Trans:Stock locked in first
Axles:locked stokers
Tires:Front cut jumbo claws Rear cut jombo swamps
WB:16 and a bit inches
Overall Widthunno
Diff clearance:4 and bit inches
Center Chassis clearance:5 and a bit inches
Overall heightunno
Overall weight:About 2 kilo's
Chris
BDR is offline   Reply With Quote
Old 05-01-2005, 09:24 PM   #8
Might as well post up a few pictures of my rig... it's about finished...
Stats:
- Old Maxx(narrow)
- RCRockGear Maxx SAS Kit
- Rockraider Chassis
- E-Maxx tranny locked in first & zero slop modification
- Big 'ol spur gear and 8-tooth pinion
- 1/8 scale buggy shocks up front & X-Factor shocks in rear
- currently 15.5" wheelbase
It's almost too clean and pretty to run on the rocks...
toyofast is offline   Reply With Quote
Old 05-11-2005, 02:30 PM   #9
Colt Python/SR9c
Truck Base : 40's willys jeep based tube frame/alum
ESC:evx with mod
Motor(s):55t lathe 9-72
Servo(s):hi tech 645mg 133 gram
Trans:e maxx
Axles:e maxx locked out
Tires:k rocks mounted on maximizers
WB:
Overall Width:15 1/2
Diff clearance:4
Center Chassis clearance:5 1/2 (bottom trans mount)
Overall height:10 3/4
Overall weight no scale sorry s/a if not less than stock maxx
Old 05-31-2005, 08:06 PM   #10
Colt Python/SR9c
The newest truck from Twisted Creations
Owner: Rufies97XJ
Truck Base : Emaxx
ESC: SR
Motor(s): Reversed MM motor with GD600
Servo(s):CS-70 in the front and Bluebird 630 in the rear
Axles: Custom Maxx axles
Tires: LST's on narrowed Hot Bodies rims
WB: 16 1/2"
Overall Width: 15 1/2"
Diff clearance: 4 1/2"
Center Chassis clearance: 5 3/4"
Overall height: 11"
Overall weight: 8 lbs.
Old 06-05-2005, 10:29 AM   #11
Project Flexx-Maxx 4x4x4
Truck Base : New E-Maxx
ESC: Jamara NoLimit
Motor(s): Multiplex Permax 600
Servo(s): HiTech 645MG front +rear
Trans: E-Maxx tranny @76/12 + Graupner reduction gearbox 2,8:1
Axles: E-Maxx, both locked with spool
Tires: Imex Jumbo Kongs on Sayville rims; cutted
WB: 42,3cm
Overall Length: 60,5cm
Overall Width: 47,0cm
Diff clearance: 11,7cm
Center Chassis clearance: 14,5cm
Overall height: 30,0cm
Overall weight: 6688g - inclusive batteries and some dirt
More pictures in hi-res: pic 1 | pic 2 | pic 3 | pic 4 | pic 5
Manuel
Uncle_Manuel is offline   Reply With Quote
Old 06-12-2005, 12:34 PM   #12
Default Here's Crawlmaxx
E-Maxx
EVX w/mod
1-55t Lathe
JR Racing Z650M
E-Maxx tranny
Hyrbid Maxx with CVD's
Cut & Shut Kongs with grooving, 3" wide, stock Maxx wheels backwards
17" WB
17" width
4 1/8" dif clearance
4 3/4" chassis clearance
12 1/2" overall height
~11 lbs
crawlmaxx is offline   Reply With Quote
Old 07-10-2005, 02:56 AM   #13
The Rockroach
Truck Base : Maxx (early series ~2000 Narrow Track)
ESC: Novak SR
Motor(s): 2 x Mag Mayhems (one reverse timing, one forward)
Servo(s): Hitec HS 5645-MG
Trans: Maxx locked in first
Axles: Locked out maxx narrow track
Tires: Maxx Mulchers
WB: 16"
Overall Width: 14.5"
Diff clearance: 3"
Center Chassis clearance: 4"
Overall height: 9.75"
Overall weight: dunno. Heavier than I would like.
Final Crawl Ratio: 8T/72T = 71:1 crawler ratio
MudCow is offline   Reply With Quote
Old 07-15-2005, 08:14 PM   #14
Truck Base : E-maxx
ESC: EVX (with mod)
Motor(s): lathe motor (1)
Servo(s): 645mg front
Trans: e-maxx locked in 1st
Axles: locked out maxx axels and arms
Tires: savage tires
WB: 15"
Overall Width: 16"
Diff clearance: 3.75"
Center Chassis clearance: 4.75"
Overall height: around 11"
Overall weight: 8.5lbs
more to come.
colin
Maxx4life is offline   Reply With Quote
Old 07-19-2005, 12:44 PM   #15
Man my e-maxx is nothing like yours.
BIGMaxx is offline   Reply With Quote
Old 07-26-2005, 10:48 PM   #16
Truck Base :Maxx
ESC:Rooster
Motor(s):Johnston 27T
Servo(s):To be CS-80's f/r
Trans:Homemade from bbq roster
Axles:Maxx
Tires:Stock
WB:18''
Overall Width:Stock
Diff clearance:3"
Center Chassis clearance:5''
Overall height:dunno
Overall weight:Freakin' Heavy
wheeler is offline   Reply With Quote
Old 07-31-2005, 09:50 PM   #17
Truck Base : Emaxx
ESC: Tekin Rebel 2
Motor(s): Integy 55T Lathe Motor
Servo(s): 645-MG Servo
Trans: E-Maxx Locked in 1st
Axles: Solid Axles
Tires: LST's on RPM Clawz
WB: 16 inches
Overall Width: 17 inches
Diff clearance: 3 1/2 inches
Center Chassis clearance: 4 3/4 inches
Overall height: 6 inches
Overall weight: 8.5 pounds
Eclipse is offline   Reply With Quote
Old 08-08-2005, 09:20 AM   #18
Truck Base : E-Maxx
ESC:Super Rooster
Motor(s):1 Magnetic Mayhem attached to t a GD-600
Servo(s):Hitec HS 645's front and rear
Trans:Stock E-maxx locked into first
Axles:Custom tube axles with E-Maxx diffs and knuckles
Tires:Lst's on narrowed Maximizer Beadlocks
WB:17"
Overall Width:16 3/4"
Diff clearance:3 1/2"
Center Chassis clearance:5"
Overall height:11"
Overall weight:11lbs 7 oz
Esteban86K5 is offline   Reply With Quote
Old 08-25-2005, 04:40 AM   #19
Colt Python/SR9c
Posted for Bipolarcrawler
Truck Base :traxxas E maxx,custom tube xo skeleton
ESC:traxxas
Motor(s):trinity 27,integ 55 lathe
Servo(s):645 hi tech fr/rear
Trans:maxx
Axles:custom alum,maxx diffs,steel cv's
Tires:modified k rock(mods a must)
WB:17"c-c
Overall Width:16"
Diff clearance:4"
Center Chassis clearance:4-1/4
Overall height:10"
Old 09-14-2005, 08:14 PM   #20
Default Pud
PYRO's MAXX/ txt contraption
Truck Base : highly modded TXT frame
ESC: SR
Motor(s): peramax 600
Servo(s): hightec 5945
Trans: modded TXT, gd- 600- 89:1 gear ratio
Axles: maxx
Tires: moabs
WB: 17"
Overall Width: 16"
Diff clearance: 3" f/r
Overall height: 9 3/8" w/ body
Overall weight: heavy
mike is offline   Reply With Quote
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/traxxas-crawlers/8540-maxx-crawlers-gallery.html
Posted By For Type Date
t-maxx off roader/rock crawler This thread Refback 10-05-2011 01:01 PM
You may not edit your posts
HTML code is Off
