09-02-2012, 04:53 PM | #1 |
Rock Crawler Join Date: Dec 2011 Location: Blacksburg
| Shock recommendations?????
In the process of building a SCX based scaler. Got a chassis from Matzilla, got some wraith axles, got some Roc lox tires and Mayhem Wheels. The original plan was to use Pro Line shocks but was thinking maybe something alittle cheaper (better)? I have a stock set of Wraith shocks, could I use those? So what do you guys recommend? SHOCKS.....SPRINGS......WEIGHT OIL? Want it to be more of a scaler than a basher. |
09-02-2012, 05:41 PM | #2 |
Rock Crawler Join Date: May 2009 Location: just north of BFE in SC
| Re: Shock recommendations?????
The stock scx10 shocks are fine. I have been running them forever and never had an issue. I am running the proline springs and 40wt oil. |
09-02-2012, 06:02 PM | #3 |
Are the wraith shocks the same as the scx's?
09-02-2012, 06:56 PM | #4 |
Rock Crawler Join Date: Dec 2010 Location: Piedmont, SC
I don't think they are. I believe I have some scx10 shocks...if I do they are yours if you want em....
09-02-2012, 10:31 PM | #5 |
Cool Wendall. I appreciate that!
09-03-2012, 07:38 AM | #6 |
| Re: Shock recommendations????? |
09-03-2012, 08:09 AM | #7 |
Rock Crawler Join Date: Oct 2009 Location: Columbia, SC
I just got my hands on a Mattzilla chassis recently too. The shock mounts are a good bit shorter than on a SCX chassis. I found that the SCX shocks worked well but sat the rig a little too high. I mocked the rig up with some shorter shocks (roughly 86mm) and it looks like its going to work well and give me a nice low stance. I think the SCX shocks are 90mm so they would also work but might need a softer spring.
09-03-2012, 05:59 PM | #8 |
Thanks for the info Creepin!
Shock recommendations????? - Similar Threads | ||||
Shock recommendations | Romad | Redcat Crawlers | 9 | 02-16-2012 03:03 PM |
shock recommendations | ofna | Axial SCX-10 | 10 | 05-13-2011 03:17 PM |
Shock Recommendations | bschimmel | General Crawlers | 8 | 05-25-2010 07:45 PM |
shock recommendations | Crawlin' | Axial AX-10 Scorpion | 36 | 04-09-2008 09:12 PM |
Shock Recommendations? | gregrocks90046 | Traxxas Crawlers | 3 | 01-04-2006 05:41 PM |
