12-31-2013, 08:10 AM | #1 |
Newbie Join Date: Jan 2013 Location: West Columbia, SC
| Scx10 honcho lack of power
In having a problem with my truck with a fully charged lipo and after running it for about ten minutes it lacks power like the battery is low not sure what is going on with it. The motor is hot to the touch. 5200mah lipo. 35T motor 20T pinon. Stock spur gear CC BEC at 6v. Any ideas what might be wrong? Sent from my XT1056 using Tapatalk |
12-31-2013, 08:15 AM | #2 |
Quarry Creeper Join Date: Oct 2012 Location: Cashmere (central WA)
| Re: Scx10 honcho lack of power
disconect drive lines and make sure nothing is binding or haning up
12-31-2013, 08:49 AM | #3 |
Rock Crawler Join Date: Dec 2011 Location: Blacksburg
When was the last time you did a complete tear down? Water is really tough on bearings and all metal parts. Do like the other guy said too. Also check your motor brushes too.
12-31-2013, 09:57 AM | #4 |
Trans and axles are nice and free. I have steel gears in the trans and cleaned/greased the rear axle, not the front yet will do that today. It's a sealed motor I can see the brushes they look ok. How is the best way to clean the motor possible bad motor? Sent from my XT1056 using Tapatalk |
12-31-2013, 11:26 AM | #5 |
I think the only way to clean a sealed motor is with motor spay cleaner. Also don't forget to oil the bearings/bushings after you clean it. The armature may be burned or really baddly grooved.
12-31-2013, 11:37 AM | #6 |
If it was burned would that cause my problems Sent from my XT1056 using Tapatalk |
12-31-2013, 01:09 PM | #7 |
If it is glazed over or burned spots on it it could.
12-31-2013, 01:58 PM | #8 |
RCC Addict Join Date: Jul 2013 Location: Planet Earth
How many packs have you run through the truck so far? Im not thinking they are oil-lite bushings in the motor where you don't need to oil them....Flush it out with some motor spray and oil it up on both ends. You should be oiling the bushing ever couple of runs and always after running through water/mud after a good motor flushing. My stock 27T ran warmer than I wanted it to with a 20T pinion...You may want to try a 17 or 16T pinion with your 35T...You will lose a good amount of speed but your temps should drop in general and low speed control will improve a whole lot. If you don't like the speed with a 16T you can try a 3s battery but be careful as its much easier to break things if not careful ,or get a better 27T rebuildable motor...should have a lot more wheel speed and close to the same power compared to the sealed can motor even with the 16T pinion. Good luck finding the issue. Last edited by 6sharky9; 12-31-2013 at 02:04 PM. |
12-31-2013, 04:50 PM | #9 |
I don't know what you mean by running pack thought it Just installed a smaller spur gear to try to help. cleaned out the motor and slot of dirt, And oiled up the bearings still getting very worm. Could it be just a bad motor Sent from my XT1056 using Tapatalk |
12-31-2013, 05:15 PM | #10 | |
Quarry Creeper Join Date: Apr 2013 Location: Upstate
| Re: Scx10 honcho lack of power Quote:
Packs would be in reference to how many battery "packs" you have ran on the motor. If your still finding issues I would chalk it up the game and get another motor to solve the problem. You can find cheap motors for less than the $20ish range, ex. (Axial 20T or the stock 27T for scx10's, Traxxas Titan motors 540 or 550 cans ranging from 12T to 20T). Finding the correct gearing can be difficult /trial and error, I would keep check on the forums motor/electronics specific for that info here on RCC. You will never look back if you get medium/highend motor, it just works that much more efficiently as long as you take of it! | |
12-31-2013, 05:49 PM | #11 |
Ok.. Is a RC4WD brushed 35t boots rebuildable RC4ZE0045. Good motor. How do you brake in a motor good way. Sent from my XT1056 using Tapatalk Last edited by thetinman85; 12-31-2013 at 08:42 PM. |
01-01-2014, 07:23 AM | #12 |
Newbie Join Date: Jan 2013 Location: lexington
don't over look your driveshafts, just a little bit of binding will make it overheat
01-01-2014, 07:55 AM | #13 |
I wanna be Dave Join Date: Jan 2009 Location: New Port Richey, FL.
| Re: Scx10 honcho lack of power That will make your situation WORSE. Go UP on the spur. Personally, I always put the largest spur that will fit first, then do performance adjustments with the pinions. Smaller spurs really load up the motor (drivetrain has more leverage on the motor) where large ones do just the opposite. Playing with smaller spur diameters is good with onroads where there is near zero rolling resistance.
01-01-2014, 09:42 AM | #14 |
Quarry Creeper Join Date: Mar 2009 Location: Yokota
Tinman I would definitely go with a rebuildable one even if you don't have a lathe or know someone with one you can replace brushes and pull them out if you gut a hung brush. Sent from me using my DNA |
01-01-2014, 11:17 AM | #15 |
Cool thanks for all the ideas will be putting all them in play. Thank you
01-02-2014, 03:28 AM | #16 |
01-02-2014, 01:32 PM | #17 |
Rock Crawler Join Date: Sep 2005 Location: Columbia, SC
Sounds like you are over geared and burned up that motor. Step down to a 14/87 and a different motor. Sent from my DROIDX |
01-02-2014, 05:54 PM | #18 |
Newbie Join Date: May 2013 Location: Charleston
I agree with skerb... I had the same problem, my wraith would run perfect for ~10 minutes then the motor would be extremely hot to the touch and I would smell a slight "clutch" smell. But, in my case my motor would not work once it got to a certain temperature. Once it cooled and I cleaned it with the electronic spray cleaner it would work again... I went the long route and replaced the stock 20t with a tekin pro4 4600kv (toooooo much power!) and mamba max pro. I went through 3 motors in a short time so this was the best route for me. Good Luck!
01-02-2014, 07:18 PM | #19 |
01-02-2014, 07:22 PM | #20 | |
Sent from my XT1056 using Tapatalk | |
Scx10 honcho lack of power - Similar Threads | ||||
Help with lack of power when bound... | Perkolator | Axial SCX-10 | 11 | 05-03-2012 03:09 PM |
ax10 lack of power on climbs | Swervin | Axial AX-10 Scorpion | 7 | 10-30-2011 12:00 PM |
T.O.M's SCX10 - The True Power of Axials SCX10 | stewbaru | Axial SCX-10 | 4 | 08-17-2011 07:30 PM |
EVX Dual Motor combo... lack of rear power | Twiztid Metal | Electronics | 1 | 08-28-2010 08:18 PM |
Lack of power | CronusTRD | Electronics | 25 | 12-19-2008 04:04 PM |
