![]() | #21 |
Quarry Creeper Join Date: Feb 2016 Location: Pembroke ON Canada
| ![]() ![]() Sent from my iPhone using Tapatalk |
![]() | #22 |
| ![]() ![]() ![]() ![]() Tried with a battery in it. As mock up it would require lots a trimming. Clears drive shaft by at least 3mm was a problem i did not think about when the curios idea hit. Sent from my iPhone using Tapatalk |
![]() | #23 |
Rock Crawler Join Date: May 2021 Location: NorCal
What you could do is move the battery tray forward (front half will be resting on the transfer case). The back holes of the tray will be mounted in the front holes.
![]() | #24 |
![]() | #25 |
Quarry Creeper ![]() Join Date: Dec 2009 Location: Strafford, NH
Depending on the size of your battery, you could Velcro it to the slider.
![]() | #26 |
![]() | #27 | |
| ![]() Quote:
Tried your idea. Would still require alot of body and cage trimming. Sent from my iPhone using Tapatalk | |
![]() | #28 |
| ![]() Next step is try modifying the tray itself. Either cut off some of the walls of the tray, or move it more forward as much as you can and drill new holes in the tray to mount it.
![]() | #29 |
![]() | #30 |
Well the weather prevented me from spray painting the body. Too much wind and rain at once. Sent from my iPhone using Tapatalk |
![]() | #31 |
| ![]() ![]() ![]() ![]() So Tires are on order should be here in the next 3 weeks. Felt only right get similar to stock size Swampers liked the looks of them on the truck. GCM Racing 1.9 Ranger Beadlocks. These where a limited run. And lastly the old rear cage mount is at a friends getting a 3D printed verison made with some other tweaks. As i do not have a pc that can handle that type of work, nor a 3d printer. Sent from my iPhone using Tapatalk |
![]() | #32 |
The 3d prototype part. ![]() ![]() ![]() ![]() ![]() ![]() Sent from my iPhone using Tapatalk |
![]() | #33 |
Got some Chippy Choppy to do to the frame which was previously mentioned. Sent from my iPhone using Tapatalk |
![]() | #34 |
Looks to me like the body needs to comeback on the chassis about 1/2" or so. I would line the peak of the wheel arches with the center of the tire personally...
![]() | #35 | |
| ![]() Quote:
That picture was taken at a angle. I did note the same thing. Here is with the tire on at full stuff. At a more of a straight picture. I think it is pretty centered. If anything i could just trim the body or deal with a little tire rub. ![]() Sent from my iPhone using Tapatalk | |
![]() | #36 |
Quarry Creeper Join Date: Jun 2018 Location: Blaine
I have a couple questions if you don't mind helping me out with the answers. 1: How accurate is the shape of this vaterra body to a 1:1 square body? 2: Could you take a shot straight on from the back to show how to cage lines up relative to the body lines? I've been looking for a pre-built cage that'll fit in the back of an RC4WD Blazer. I know the RC4WD and the Vaterra are modeled after different years but Vaterra cage looks like it's about the shape I'm looking for. I might be able to make it fit if it's close enough. Sent from my LM-V600 using Tapatalk |
![]() | #37 | |
| ![]() Quote:
![]() | #38 | |
| ![]() Quote:
When i get the truck body back i will attempt to awnser your questions. I never been compared a 1:1 to a 1/10 scale. Not sure what dimensions you need? Sent from my iPhone using Tapatalk | |
![]() | #39 | |
| ![]() Quote:
The RC4WD Blazer is decently close to 1/10 in height, length and WB, but had been widened to fit the chassis. Is the Vaterra the same way? Sent from my LM-V600 using Tapatalk | |
![]() | #40 |
All the super swampers arrived! Great way to end a stressful day at work. ![]() Sent from my iPhone using Tapatalk |
SSD Trail King - Trail Run - 06-13-2021 | soze | Scale Videos! | 0 | 11-02-2021 06:34 PM |
SSD Trail King - Trail Run - 1/10/2021 | soze | Scale Videos! | 1 | 09-20-2021 07:43 PM |
My Take on the SSD Trail King | neilus | SSD Trail King - Pro Scale Chassis Builder Kit | 48 | 03-24-2020 04:09 PM |
SSD Trail King is now $369.99! | SSD | New Products and Great Deals | 0 | 10-04-2019 04:13 PM |
SSD Trail King | Toothless9 | General Crawlers | 2 | 09-03-2019 06:57 PM |
