02-04-2012, 02:32 PM | #21 |
Quarry Creeper Join Date: Dec 2006 Location: Prescott
| Re: Winks Super rebuild for 2012
This is were i picked up mine. All Shrink Wrap pricing is per foot. |
02-06-2012, 10:31 AM | #22 |
Rock Crawler Join Date: May 2007 Location: Prescott
| Re: Winks Super rebuild for 2012 Thanks Darwin for dropping off the shrink wrap. I hope to get some pics up this evening. It took me a while to figure out how I wanted to lay out the electronics. Since the truck dropped a pound when switching axles I feel like I need to drop weight out of the chassis. Pics coming soon.
02-15-2012, 09:15 PM | #23 |
Finally got a new camera. I had a hard time figuring out which camera to get and find the best deal on it. I decased the BRXL's and shrink wrapped them together. I also made a electronics tray out of thin delrin for the twin BRXL's, twin BEC's and the 3S battery. Next I wanted to get more caster with these axles so I had the tubes turned down to accept the Vanquish 8 degree chub and knuckle. I am not sure on the best way to secure the knuckle to the tube. Either a bolt through both or tap the chub and use set screws. Here it is somewhat back together. Sure could use some input on best practice on the chub to tube. Also I am needing a source for the tierod cause it is longer than I can get from lunsford. |
02-15-2012, 09:19 PM | #24 |
RCC Addict Join Date: Feb 2008 Location: Crawlerado
3/16" music wire FTW!
02-15-2012, 09:38 PM | #25 |
I wanna be Dave Join Date: Jan 2009 Location: laying low
I just did the 8* on mine...I drilled two 3mm top and bottom of the chub...then did two 4mm on the holes that were already in the chub. I just used set screws...and dug them into the tube it seems to be holding well after 1 comp and 5-6 practice pack.... mine are on delrin tube though...I'm sure you could do the same on the alum and not have them move...or just dimple the tube where you want the set screws and your for sure not spining the chub then. |
02-15-2012, 09:39 PM | #26 |
how wide is your rig with those hubs!?!?!? are those 600's??
02-15-2012, 09:46 PM | #27 |
I used set screws for my 8* c's, but looks like some one tried to counter sink the c's. Other then that it can still be done either way. Oh, one reason i used set screws was cuz i had play from c's to the tubes. Hope this helps.
02-15-2012, 09:50 PM | #28 |
Its coming together good. U trying to get it ready for this weekends local comp?
02-15-2012, 10:43 PM | #29 | |||
| Re: Winks Super rebuild for 2012 Quote:
They are 600's and the track width is 13.75. It is a little bit too wide but I am trying to figure out width versus steering into the lower links and such. Quote:
Seriously? Well I guess I better go to a hardware store and see what they have. I do have some 1/4 square aluminum rod. | |||
02-15-2012, 11:43 PM | #30 |
| Re: Winks Super rebuild for 2012 |
02-16-2012, 06:34 AM | #31 |
02-16-2012, 06:53 AM | #32 |
| Re: Winks Super rebuild for 2012 Pick up a fresh 10-24 die when you go. I've been running poor man's ti for quite a while with no issues. If it flexes too much, sleeving it with 1/4" stainless and you'll never have problems |
05-21-2012, 06:37 PM | #33 |
Things have been slowly progressing but here it is. Updated to HPI Blast wheels narrowed down to 1 inch and Vanquish 225 hubs with 7.75 rovers. Set the caster in place and this thing is ready to kill it again. |
05-21-2012, 06:55 PM | #34 |
I wanna be Dave Join Date: Dec 2006 Location: Goin broke losing weight.....
Looks good Ryan. I need to get back to messing with mine.
05-21-2012, 08:32 PM | #35 |
Looks good man! I like that electronics plate.
06-17-2012, 06:09 PM | #36 |
Taking the next step and dropping more weight. I am hoping to get under 6 pounds but not sure if it is possible with a limited budget. Here I go. Starters. I had the axle tubes turned down and I will shave down the cases this week. Since I am on a tight budget I will be drilling the gears myself at a friends shop. Hope that turns out good. Next will be aluminum screws and delrin spacers in the V3 Carbon fibre YTC chassis. |
06-21-2012, 04:11 PM | #37 |
Quarry Creeper Join Date: Sep 2010 Location: Port St Lucie
Wink your Super is looking Awesome!!!!! Do you have any pics of the gears you drilled. Im anxious to see what you did? |
06-27-2012, 05:24 PM | #38 |
Rock Stacker Join Date: Jun 2011 Location: Valley of Chino
that looks like some real hillbilly machine work on your tubes??? |
06-28-2012, 08:11 AM | #39 |
06-28-2012, 09:26 AM | #40 |
Winks Super rebuild for 2012 - Similar Threads | ||||
HLC 2012 Super Sport | highlandcrawler | Team Losi Comp Crawler | 27 | 12-07-2011 01:27 AM |
2011/2012 Season Super Build... | Arct1k | Superclass Crawlers | 4 | 07-04-2011 06:24 AM |
Spy photo 2012 SUPER | dboy1k | Chit Chat | 7 | 01-26-2010 03:45 PM |
Super rebuild | DeaDShorT | Tamiya Clod Buster | 10 | 10-02-2009 06:39 PM |
Super rebuild.. Is this electronic setup good? | sierradmax | Electronics | 0 | 02-12-2009 03:48 PM |
