05-16-2014, 05:09 AM | #21 |
Pebble Pounder Join Date: Nov 2005 Location: south jersey
| Re: Filotr14lsdude's Super switch
Awesome to see updates! Video of the new steering in action? How do you like the pit bulls vs the pins?
05-16-2014, 05:24 AM | #22 |
Rock Crawler Join Date: May 2012 Location: Australia
Thanks mate. I haven't taken any video just yet. I am hoping to get some shortly. I'm really liking the pitbulls. They hook up really good. I shaved and sipped them, these mods transformed the tires. So much so that I haven't ran the pin tires for quite a while now. I'm not sure when ill use them. I've noticed because of the closer tread blocks you don't have the hop you have with a lugged tire. They preform similar to the pins that I have. I forgot to mention it earlier, the uni shafts are made from chromoly steel so they should be strong enough to handle what I can throw at it. |
05-17-2014, 01:11 PM | #23 | |
Quarry Creeper Join Date: Nov 2013 Location: Pittsburgh
| Re: Filotr14lsdude's Super switch Quote:
05-17-2014, 02:30 PM | #24 |
It was the gears on the strenghtener. I mainly drive this on more bolder style rocks so there's lots of holes and strange edges. It got to the stage where it would skip at every rock. The front was the only one that skipped aswell. It was strange and annoying |
05-17-2014, 03:58 PM | #25 |
Mine is doing the same shit, I trimmed the gear down on the front but didn't do the rear and after that the front skips.
05-18-2014, 10:56 AM | #26 |
Quarry Creeper Join Date: Oct 2013 Location: Skamania County
| Re: Filotr14lsdude's Super switch Wow 2 huge thumbs up on your build. I am super jealous about your pitbulls too. On my 2.2 I've ran Sedona's, BC's, Rock Grabbers, and Pitbulls. And with what I crawl on and how I crawl the Pitbulls are my best gripping tires. I love them! I contacted CI and begged him to make a set of Pitbulls for me, but he wouldn't If you ever decide to let go of them Awesome work, I am considering the servo gear strengtheners. The decision seems bias because I read lots of good stuff, then sometimes not so good. Again very very cool rig!! |
05-19-2014, 02:54 PM | #27 |
Thanks for the kind words. The pit bulls are great. I emailed CI a few times over a long period to see if he would be interested in making any super tires. He contacted me saying he wants to make some super pitbulls, so I jumped on them. These are the result and I'm very happy. It's hard to say about the servo strengtheners. I really enjoyed using them,the power is amazing. I sucked when they popped. It got to the stage where I had to carry a spanner in my pocket and fix it up ever 2 meters on the rocks. |
05-19-2014, 07:45 PM | #28 |
Pebble Pounder Join Date: Oct 2009 Location: underground
How was the servo strengther's skipping gears is it when the axle flexes?
05-20-2014, 01:53 AM | #29 |
When the wheels in a bind the power of the strengthener would keep moving the gears, I'd say that the plate that holds them and the servo out put shaft flexing together allowed then to skip. I checked the spigot inside the servo as suggested in the thread. No problems there Even with the gear mesh as tight as I could get it, it would still skip. It was only ever the front aswell. The front takes a lot of abuse. Dual servos is amazing so I'm very happy with the change |
05-20-2014, 07:53 AM | #30 |
Sorry you had issues with the strengtheners. They are not the easiest product to setup and youre not the first to have issues. It may be too late, but there are some things to look at when setting them up. As you found out, if they veer anywhere from a perfect setup, you can have problems. First thing is to have the linkages straight when looking from the front. Looks like yours were dead on from what I can see. I have also found it important to have the gear mesh as tight as possible, maybe even a bit of pre load if you could, you said you had this in check too, but just to help others. I tighten my nut on the bearings as tight as I can. Thats quite a bit since its a big wrench youre putting on there. To give an idea of how much I tighten it, I have broken a threaded post and many AL nuts. I finally got rid of the AL nut. I think they were flexing a bit and allowing some slop and went to steel. Ever since I went to a steel nut, I have not had mine skip even in the biggest binds. Its really hard to explain how to get these to function or see what a problem is without having them in hand to see what is going on. If I had to diagnose the problem from the net, I would say that your problem may have been that the drag link or steering arm were too short or even both. If youre steering has the possibility of camming over, to me, that says that it could possibly be operating in a zone where instead of pushing and pulling in a straight line, when it gets to either end of the spectrum, it will want to start pushing upwards on the gear/arm and this makes the plate flex and skip gears. When I set my drag link up, I make it so when it turns full right that the rod end touches the carbon plate. Then, when steering back, if it cams over or looks like it is pushing up on the gear instead of in a straight line, this is when you need to use the longer arm to have a smaller throw and stay in that zone. When you go to the longer arm, you need to setup the drag link to hit the carbon again. Looks like you have moved on, I hope it was ok to post this in your thread as there seems to be a lot of questions about them in here. Again, sorry that you had issues. |
Filotr14lsdude's Super switch - Similar Threads | ||||
Chaotic Super Switch Bodiless Carbon Chassis | Chaotic Crawlers | Superclass Crawlers | 18 | 08-05-2016 04:24 PM |
Light Switch for Your Scaler - Firmtronics RC Switch Review | roktoy | Electronics | 29 | 09-15-2015 02:37 PM |
Wiring a switch to switch polarity | builder | Electronics | 5 | 05-20-2013 07:55 PM |
Super Exzes "Dig" switch | gimpygolden | Electronics | 6 | 03-09-2009 10:04 PM |
super rooster switch | bigtiresrbetter | Electronics | 6 | 08-28-2007 08:06 PM |
