Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Superclass Crawlers
Thread: new build
Old 02-26-2015, 06:09 AM   #1
Default new build
Ok im not new to the rc crawling scene, i own two of em, axial ax10, and curently building a custom scx10. After looking at the super class crawlers on here i figured id build one, but have no idea where to start. any help would be great. thanks
countryboy48 is offline   Reply With Quote
Old 02-26-2015, 07:28 AM   #2
Default Re: new build
a good set of 1:8 axles (try dlux)
1:8 chassis (try dlux or dravpnir)
links, or rod and rod ends and appropriate taps and/or dies
2 35t hi torque motors (brood or holmes hobby), 2 escs, a cc bec,
at least 2 hi torque metal gear servos - or 4: 2 at the front, 2 at the back
servo mounts, battery mount, batteries, battery charger
wheels (try dlux), 12 voodoos (to cut and shut)
I favor a stick radio, at least 6 channel preferably 7 or 9
scews, nuts, 13 gaqe wire, wire ties, deans connectors, bullet connectors,
lexan sheet for body panels, paints
tools for all the above
or
rc4wd has some super bully axles, servo mounts, a pretty good super chassis with links
as does billet works design. rc4wd also has some wheels and tires. Integy also has
some super size wheels and tires but ....
then there is nitrorcx and the madtorque. considering those are plastic bergs...
there is some hope
then there is the redcat super rock slide. it is a monster
then there is the original clod moa axles. you can get the Tamiya plastic ones or the
integy metal copies.
there are several ways to go with supers. what do you want out of yours?
as you look at the pictures in the gallery you can tell some are shelf queens and some are bashers
and some are serious compers.
this should get you started
have fun, supers are great
cabron is offline   Reply With Quote
Old 02-26-2015, 07:47 PM   #3
im looking to build a competition compliant crwaler that will perform well. im not looking for evryone to give away their secrets here, just dont know whats comp and not. kinda need rules and specs so i can have something to go on. and what are voodos?
Old 02-26-2015, 08:01 PM   #4
You need USRCCA rules it's toward the bottom of the forum list. This link should take you to it.
http://www.rccrawler.com/forum/usrcc...-rulesets.html
You want the traditional comp class rules I believe.
Irwin Fletcher is offline   Reply With Quote
Old 02-26-2015, 09:16 PM   #5
in the super section everyone is giving away their secrets, most (of those secrets) are for sale. Then you have to figure out how to drive it. (thats the tough part)
Curcal is offline   Reply With Quote
Old 02-26-2015, 11:45 PM   #6
ottsix came out with some killer tires a short while back
great compound, very adaptable tread, seems to get better with use, several softnesses.
they are the current "best tire" in most peoples' opinion
wish I could afford a couple of sets, I have to make do with rovers, panther leopards, and sedonas.
new build - Similar Threads
scx10 G6 2.2 Wroncho/Wrangler Build (AKA The Sleeping On The Couch Build) Irishchamp 2.2 Scale Rigs 45 10-09-2014 10:26 PM
Jeep scaler build and comp micro crawler build droopmodmrc Losi Micro-Rock Crawler 1 12-25-2012 12:34 PM
~53 Willys 2010 Comp Rig Build~ RC4WD MOA Worminator Build~ 53 willys General Crawlers 108 11-28-2011 12:42 AM
RcBros LCC Build, Hi-Res pics & More Build!! RcBro Team Losi Comp Crawler 30 06-03-2009 07:26 PM
