06-09-2017, 02:41 PM | #1 |
Rock Stacker Join Date: Sep 2008 Location: NYC
| Just ordered my Bruiser!!!
I'm so excited. I've waited 32 years to own one of these. I'm 39 now if that says anything. Anyway, I didn't realize that Tamiya had re-released the Bruiser back in 2012 until yesterday. I was perusing Tamiya's website for some nostalgic reason (had a Blackfoot, Hotshot, and Grasshoper back in the day) when I saw the Bruiser. Then and there, I knew I had to have it. So... did a bit of reading and whipped out the credit card 30 minutes ago. Now just waiting for Tower Hobbies to ship. Apart from the Bruiser kit, I ordered the RC4WD beadlock wheels and the Tamiya slipper gearset for the transmission. Right now I only have a 3 channel Spektrum that I use for Losi 5ive-T and my Redcat XB. Can I use the 2 position 3rd channel for the transmission and set it to only shift from 1st to 2nd? I will eventually get another multi-channel radio down the road but was wondering if I can use 3 channels for now? |
06-09-2017, 02:48 PM | #2 |
| Re: Just ordered my Bruiser!!!
Congrats (felt the same way when I got mine) and yes a 2 position switch means only using 2 gears.
06-09-2017, 02:56 PM | #3 | |
| Re: Just ordered my Bruiser!!! Quote:
Also, it's been so long since I've painted a hard shelled body like what the Bruiser has. Are all of you guys/gals using air brush guns or can i get away with some high quality Tamiya spray paint? | |
06-09-2017, 04:09 PM | #4 |
Just out of curiosity, but what's the difference between the Mountain Rider and the Bruiser to justify the Bruiser's higher price tag?
06-09-2017, 05:55 PM | #5 |
Last question for the night... manual says not to use anything except the included Mabuchi can. If I recall, that's a 27T motor, so basically a good compromise between speed and torque. I do have a Novak Rooster Crawler and Novak 55T brushed motor sitting in one of my parts boxes. Anyone run a 55T in their Bruiser, and if so, was it too slow even in the higher gears? I'm thinking that since the Bruiser is quite heavy for 1/10 model, the 55T motor should be OK to use. I'm not planning on speeding with the truck anyway. Thoughts?
06-10-2017, 04:36 AM | #6 |
Quarry Creeper Join Date: Dec 2010 Location: Australia
| Re: Just ordered my Bruiser!!! Bruiser is Blue with rear cab Mountaineer is red with rear roll bar same everything else do the servo relocation mod and it will be sweet |
06-10-2017, 08:08 AM | #7 |
I paint my shells with Krylon Fusion paint for durability and cost. Tamiya paints are probably a little better finish-wise since they are made for models. A 55t would be fine. Tamiya recommends a 27t as the max motor for the transmission, though I suspect it can take more power. Any turns higher then 27 would be fine though. A 55T would give much more scale speeds - might be a little too slow. All depends on how you want to drive it. |
06-10-2017, 08:37 AM | #8 |
Congrats on the Bruiser! I'm jealous. I've always wanted one.
06-10-2017, 10:12 AM | #9 | |
Now if I can only find a set of Nick Rummy modded axles for 1.9 wheels, I'll be set. There's no way I'm going to hack up my new axles... for now at least. It's too bad RC4WD doesn't make 1.9 scale Bruiser wheels with the correct offset. | |
06-10-2017, 10:15 AM | #10 | |
I ordered my Bruiser through Tower yesterday and used a $75 dollar coupon which brought the kit price down to $704.99. The Mountaineer on the other hand was $699.00 without the coupon. Could've saved more money and just bought the half cab down the road. Oh well. | |
06-10-2017, 10:19 AM | #11 | |
BTW, what part of PA are you in? I've got a house up in NEPA with several acres, but spend most of my time in NYC because of work. Suffice it to say, I do most of my RC stuff at the house. | |
06-10-2017, 10:46 AM | #12 |
| Re: Just ordered my Bruiser!!! I'm in SEPA. About an hour northwest of Philly.
06-10-2017, 10:18 PM | #13 |
Newbie Join Date: Sep 2013 Location: Cedar Fort
I didnt want to hack up my axles either so I used gearhead beadlocks. They are adjustable offset and I got the tires to ne up perfectly on the stock axles. Sent from my SM-G935V using Tapatalk |
06-10-2017, 10:24 PM | #14 |
Here is another view Sent from my SM-G935V using Tapatalk |
06-11-2017, 10:29 AM | #15 | |
Are you using the stock Bruiser hubs or did you convert to 12mm hex? Last edited by amstel78; 06-11-2017 at 10:31 AM. | |
06-11-2017, 12:10 PM | #16 |
Oh sorry I converting to 12mm with the kit from rc4wd. The beadlocks have several adjustments internally and with different hub sizes you can match the front and rear perfectly. The wheels are 2.2 CAC EZ-loc delrin. Sent from my SM-G935V using Tapatalk |
06-11-2017, 12:15 PM | #17 |
Here are a few pics of the wheel, hubs and the lineup. Sent from my SM-G935V using Tapatalk |
06-11-2017, 12:19 PM | #18 |
I have a running video on youtube. Check out "old west bruiser." Sent from my SM-G935V using Tapatalk |
06-14-2017, 04:02 PM | #19 |
My Bruiser kit was delivered today along with some Proline Flatirons and a set of RC4WD Truescale beadlocks for the Bruiser. Question is - how do the RC4WD Bruiser wheels attach to the stock hubs? The original wheels are secured by 3 screws. I don't see how that would work with the RC4WD wheels??? These are the wheels in question: Truescale Series Bruiser Beadlock Wheels BTW, my kit came with the bonus Tamiya blue/red brush. I thought those were only packed in the first year re-release boxes? |
06-28-2017, 03:16 PM | #20 |
It's been a few weeks since I ordered my Bruiser, and between kids and work haven't had much time to assemble the kit except for a few hours here and there at night. Well, I finally finished the mechanical portion and am now waiting for the weekend to tackle the body. I was intending to use my Rooster Crawler ESC and Novak 55t motor but didn't have enough 14awg wire for an extension. So in the meantime, I used an old Axial ESC and the stock motor with supplied extension leads. As for the battery switch, none of the two ESCs had a Tamiya style switch that would screw into the electronics box top. So, I ended up stuffing a 5 cell receiver battery pack into the box and used a spare RC switch I had laying around. Btw, is it just me or did the instructions for the slipper clutch seem confusing? It took me an hour to figure out how that thing went into the gearbox. Some pics: Sent from my LG-H918 using Tapatalk |
Just ordered my Bruiser!!! - Similar Threads | ||||
Kit Ordered, Parts Ordered, Suggestions??? | OkinawaCrawler | Tamiya XC/CC01 | 6 | 02-21-2014 09:52 AM |
TF2 vs Tamiya Bruiser vs RC4wd Bruiser | blazerk5 | General Crawlers | 1 | 07-13-2012 11:49 PM |
tribute to the legendary bruiser/mountaineer RC4WD bruiser | el barto | 2.2 Scale Rigs | 12 | 11-04-2008 08:12 AM |
